88 crx si brake booster
i have a leaking mc possibly putting brake fluid into my brake booster
i have had this high idle problem as well
i read a post that possibly connected the two
the brake booster is leaking vacuum do to the brake fluid and causing my engine to idle high possibly\
my brakes seem to show a low pedal and pressure or power to them
so what i want to ask is if anyone out there could tell me
if i pull the vac line from the booster an my theory is correct will i see brake fluid?
or can i plug up the vac line and run the engine to see if it idles high?
any comments appreciated, thank you
yes there are alot of things
but i have tried many of them to correct it
i have very noticeable signs of a leak in the back of my mc onto my brake booster and it seems to me that my pedal and
pressure on my brakes is all messed up so....
if i was loosing vacuum there it would explain everything.
Randysi
26
Jul 26, 2012 03:28 AM
boarding2008
Jul 4, 2010 12:08 PM
