NEED HELP WITH WIRING OBD0 TO OBD1
Old Oct 19, 2003 | 06:00 PM
88mugencrx's Avatar
Default NEED HELP WITH WIRING OBD0 TO OBD1
Im wiring a obd0 to obd1 i bought a 88-91 obd1 dx harness it plugs up prefect...but when i when to put up my ecu it wont start....it feels like it wants to start but when i hit the gas it feels like it dies....i got a obd0 to obd1 ecu jumper...what do you change on the dx plugs so it will start....please help me...Tony
Old Oct 19, 2003 | 06:06 PM
Redline130's Avatar
Default Re: NEED HELP WITH WIRING OBD0 TO OBD1 (88mugencrx)
Have you already made the wiring changes to convert from DPFI to MPFI? What ecu are you using? What kind of motor did you drop in to your car?
Old Oct 19, 2003 | 06:21 PM
brent_G's Avatar
Default Re: NEED HELP WITH WIRING OBD0 TO OBD1 (Redline130)
yea...did you change the dizzy and 4 wire o2 and injectors and take out the resistor box, its not a simple plug and play with just using a differnet ecu and jumper. I doubt thats what you did...well i hoipe you didnt do that.
Old Oct 19, 2003 | 06:31 PM
88mugencrx's Avatar
how do you change it to multi-point....i try to do it but im not sure...i drop a d15b jdm sohc vtec...im running a jdm chipped p08
Old Oct 19, 2003 | 06:35 PM
88mugencrx's Avatar
Default Re: NEED HELP WITH WIRING OBD0 TO OBD1 (screamincivik)
i got a 4 wire 02 sensor its not on but i thought that it will work like that...i change everything to obd1...on the engine...will it run without the 02....
Old Oct 19, 2003 | 08:48 PM
Caleb V's Avatar
IM me if you need a harness built for your setup, I'll need your old core DX harness though.
CraiGlOl
Feb 7, 2009 03:03 PM
xiong1001
Jul 13, 2008 02:13 PM
tsr2
14
Dec 2, 2006 10:23 AM
Mefain
Feb 16, 2004 09:39 PM
