Changing Timing Belt
Old Oct 19, 2003 | 03:39 PM
DrunkNRacer's Avatar
Default Changing Timing Belt
I want to do it.. because i know I can do it right..
I am going to get a Helms manual soon for the car.
I want to get this done by this weekend.. anyone know of any
online guides (with pics) where they can give me an overview
of changing a timing belt on a f22b2 engine.. ??
Old Oct 19, 2003 | 06:16 PM
Kwicko's Avatar
Default Re: Changing Timing Belt (DrunkNRacer)
Today's your lucky day. I found this (http://www.cybertrails.com/~pu....html) site a little while back, through a link posted up on this very site.
I wish I'd found it before I did the T-belt swap on my '91 Accord (F22A1); it might've saved me some time.
This looks to be for an F22A, but I doubt there's a huge difference in the B...
Mike
Old Oct 19, 2003 | 07:01 PM
Default Re: Changing Timing Belt (Kwicko)
Your the ****
P.S - does anyone think this timing belt http://cgi.ebay.com/ebaymotors...57016
Would be a good buy?? Or should I buy OEM ?
Modified by DrunkNRacer at 11:22 PM 10/19/2003
Old Oct 19, 2003 | 08:43 PM
david90's Avatar
welcome to the club. I'm thinking of changing my tb too. Plus water pump and all the seals. Tell me how it goes yes? I'll let ur car be a lab rat. jk.
Old Oct 19, 2003 | 09:55 PM
badassaccord's Avatar
Default Re: (david90)
Buy OEM not shitty aftermarket stuff. Buy from the company that MADE your car, you will regret it otherwise.
Old Oct 20, 2003 | 04:06 AM
TouringAccord's Avatar
H-T Order of Merit
Personally I would spend the extra $40 for the OEM belts. As I'm sure you know, these are one of those parts you want to be cheap about.
Old Oct 20, 2003 | 05:27 AM
Elvis1977's Avatar
USE FACTORY HONDA PARTS!!!!!!
Old Oct 20, 2003 | 06:07 AM
Nick H's Avatar
New User
Default Re: Changing Timing Belt (Elvis1977)
just remember what will happen if the timing belt snaps...you may be missing chunks of your block...go oem on the t belt...
Old Oct 20, 2003 | 12:41 PM
v4lu3s's Avatar
RTFM
if you pay $70+ for a timing belt you goto screwed.
i jsut got mine from hparts.com for $37 while o'reilly auto parts wanted $57...
Old Oct 20, 2003 | 04:22 PM
H-T Order of Merit
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">if you pay $70+ for a timing belt you goto screwed.
i jsut got mine from hparts.com for $37 while o'reilly auto parts wanted $57...</TD></TR></TABLE>
Did you buy just the timing belt or did that price include both the timing belt and balancer shaft belt? Just for referrence, I based my price off of HondaAutomotiveParts. Basically, the point of my post was to go with OEM parts.
I bought my Timing Belt, Balancer Shaft Belt, P.S. Belt, Alternator/Compressor Belt, Water Pump and Water Pump Gasket from TAS for about $150.
Old Oct 20, 2003 | 06:15 PM
Default Re: (TouringAccord)
Can someone give me the part # for both belts needed
Old Oct 20, 2003 | 06:42 PM
v4lu3s's Avatar
RTFM
umm i havent used a balance shaft belt in 2 years
its a waste of power.
Old Oct 20, 2003 | 06:55 PM
AngryTroll's Avatar
Replace your cam seal.
Replace your water pump.
Install balance shaft seal retainer (if it's not installed already).
I'm working on an ecommerce site that offers high demand OEM parts. If you want parts, I have everything you need (all OEM and new, of cource). If you are interested, let me know and I'll post a price on the whole kit (including valve cover gasket and Honda antifreeze). I'm sure I can beat the online store's price.
Old Oct 20, 2003 | 07:01 PM
Default Re: (AngryTroll)
Lets See the PR.. For Both Belts .. those seals and pump.. individually please.. not total price .. thanks alot
Old Oct 20, 2003 | 08:16 PM
Kwicko's Avatar
Default Re: (DrunkNRacer)
And it would be a good idea to check the front main crankshaft seal while you're in there, too. It's pretty easy to change out if it's leaking. The way I see it, once I've got all that stuff off the front of the motor, I really don't want to have to go back in there for a while.
Mike
Old Oct 20, 2003 | 08:31 PM
AngryTroll's Avatar
Water Pump: 38.99
Honda Antifreeze: 7.99
Valve Cover Gasket: 8.95
Cam Seal: 3.00
Balance shaft seal: 3.00
Retainer Kit: 4.12
(dipstick o-ring, balance shaft retainer)
Timing Belt: 29.99
Balance Shaft Belt: 21.99
Honda Bond: 8.38
ATF: 2.95
Manual Trans Fluid: 3.17
Honda Oil Filter: 4.00
Oil Drain Plug Seal: .20
Trans Drain Plug Seal: .78
Brake Fluid (pint): 2.48
Power Steering Fluid: 3.98
Honda Throttle Plate/
Induction Cleaner: 4.12
Honda Silicone Spray: 3.98
Krex Fuel System Cleaner: 4.98
Krex Graphite Oil Additive: 4.98
Old Oct 20, 2003 | 08:35 PM
iam7head's Avatar
buy oem's there's couple thing you want from honda..
the thermotat and the timing belt, oh yeah...oem all the way
Old Oct 21, 2003 | 03:04 AM
H-T Order of Merit
those look like good prices.
Old Oct 21, 2003 | 03:08 AM
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrunkNRacer &raquo;</TD></TR><TR><TD CLASS="quote">Can someone give me the part # for both belts needed</TD></TR></TABLE>
Timing Belt: 14400-POA-004
Balancer Shaft Belt: 13405-POA-J02
Didn't know if you still wanted them but there they are.
Old Oct 21, 2003 | 09:13 AM
88LXiProject's Avatar
get a honda belt! you will be pissed if you're off a tooth... trust me. and if you have high miles, you may need a new tensioner. make sure you align the crank with the cam(s) @ TDC... if not you can shop for a new head cuz yours will be trash.
oh, and have a 12-pack with you b/c you will need this as well.
have fun
Old Oct 22, 2003 | 06:06 AM
jweller's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AngryTroll &raquo;</TD></TR><TR><TD CLASS="quote">Water Pump: 38.99
Cam Seal: 3.00
Timing Belt: 29.99
Are these prices good on F23 parts as well? I've got a friend who needs his done soon, so maybe I'll send him your way instead of to majestic for parts
Old Oct 22, 2003 | 01:40 PM
AngryTroll's Avatar
Default Re: (jweller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller &raquo;</TD></TR><TR><TD CLASS="quote">
Are these prices good on F23 parts as well? I've got a friend who needs his done soon, so maybe I'll send him your way instead of to majestic for parts </TD></TR></TABLE>
Absolutely. Send me a list of parts needed, the year and model and I'll send you a total with shipping.
The-Kid
Feb 28, 2007 05:35 PM
jimjonez
Feb 28, 2007 02:59 PM
chibiko
Feb 22, 2007 05:45 AM
itr1235
Jan 8, 2004 11:49 AM
Petah
Jun 18, 2001 07:00 AM
