need help w/ dohc zc swap
From: chillin in that city called queen creek, but homes the atl
ok heres the story i have a 91 civic dx hb and i already switched it from 2 injection to 4. a friend of mines gave me a dohc zc swap that he had sitting in his garage for helping him do a swap. now the motor is complete it has the zc tranny and it has a si wire harness but that dosent matter to me. now heres my ?'s
1st i want to puit an si tranny on it and i heard somewhere toturn a 4 spd to a 5 sd u need to change the hub splines or the whole wheel hub ture or false
2nd the crank angle sensor is broke where can i get another one from and what other car has one of those i was thinking a 86-88 integra had one put i am not sure
3rd ok now since it come w/ the zc tranny and i want to put the si tranny on it and since i am goiung to be taking the tranny off what clutch and flywheel do i use the one from the si or does it have to be a zc clutch and are the fly wheels the same for either tranny
4th ? it has a dissy on it but if it turns out that the dissy is bad what other car has a compatible dissy that can be used
and my last ? i'm going to put a turbo set up on it too and i want to get some cam gears and a fuel rail and fpr. who makes the cam gears and what motor are they compatible too and the same for the fuel rail i want aem
i think thats all i have so all help will be deeply appreciated thanks in advance
1st ?- I think the axles inner spline counts are the same so you can use your stock axles if you dont want to change hubs. I know this is true on Hf CRXs.
2nd ?- The 88-89 Teg crank sensor should work fine.
3rd ?- You match the clutch and flywheel to the year of the tranny.
4th ?- 88-89 Teg distributor works.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loaded Butane »</TD></TR><TR><TD CLASS="quote">1st ?- I think the axles inner spline counts are the same so you can use your stock axles if you dont want to change hubs. I know this is true on Hf CRXs.
4th ?- 88-89 Teg distributor works.</TD></TR></TABLE>
thanks guy any one else experienced in thge art of zc
1st, if you use an usdm si tranny, just use your stock axles/hubs. the tranny side of the axles are the same as the si, the hub side might be different.. regardless, just use the dx axles and hubs.
3rd, use the clutch that's appropriate for your tranny. here's a compatibility chart:
http://www.gamesbbs.com/~dmoore/tranny.htm
4th, what he said, 88-89 teg dizzy
If your car has a 4spd in it than it is not a DX, it's an STD. And you can use your stock axles with the Si tranny and leave your knuckles in and it will be fine.
88-89 Integra
Use the clutch and flywheel for whatever year that tranny is.
88-89 Integra
JUN makes cam gears for the DOHC ZC
88-89 Integra
88-89 Integra
