Overheating problems, please help!
Old Oct 19, 2003 | 01:06 PM
BseriesHatch's Avatar
Default Overheating problems, please help!
I have a B20Vtec hatch with a stock 92-95 radiator because the car used to be turboed. Whenever I drive on the freeway the temp needle starts to rise. When i'm just cruising the streets it doesn't do that but. But when i race on the freeway it gets real close to overheating. I already replaced the thermostat and pressure checked the radiator and all is good. So what do you guys think the problem is? Any suggestions would help because it is really getting annoying whenever i race. Thanks.
Old Oct 19, 2003 | 01:18 PM
spaceman's Avatar
Default Re: Overheating problems, please help! (BseriesHatch)
make sure none of the hoses are crimped,check the water pump. get an aftermarket thermoswitch to make your fan come on earlier
Old Oct 19, 2003 | 01:44 PM
civickiller's Avatar
Default Re: Overheating problems, please help! (spaceman)
water pump ? maybe the radiator
Old Oct 19, 2003 | 04:26 PM
revhigh89's Avatar
Default Re: Overheating problems, please help! (civickiller)
i think the radiator is too weak ,its a civic one, get a b series one at least....
Old Oct 19, 2003 | 04:49 PM
Redline130's Avatar
The 92-95 civic radiator should be able to handle the motor. Does your fan work? What type of fluid are you using (coolant and water, just water, etc.)?, and like the others have mentioned, check out your water pump. Is there any leaks from the motor?
Old Oct 19, 2003 | 08:08 PM
ACRProject's Avatar
Sounds like your water pump is going out. i had this problem with my b16...everytime i would drive 70-80 mph which is about 4500rpm, my needle would raise up almost to the red. changed my water pump and haven't had a problem since.
Old Oct 20, 2003 | 06:11 PM
Default Re: Overheating problems, please help! (ACRProject)
Cool, i will try and replace the water pump and let you guys know the outcome. Thanks.
carrollrucker
Aug 28, 2013 11:09 PM
MFButler
Mar 11, 2010 11:30 AM
bigslimdog
Aug 10, 2004 03:37 PM
crxtreme27
Jun 26, 2003 11:14 AM
