DIY painted a lip, any way to make it more glossy/smooth?
Old Oct 19, 2003 | 12:12 PM
alfaaay's Avatar
Default DIY painted a lip, any way to make it more glossy/smooth?
I just sprayed a front lip that I recently picked up. Here was my process:
-sand down
-primer
-paint
-clear coat
The color matches pretty well, but it looks a little rough still. Is there a way to help this out? I was thinking about trying to wet sand it and then go at it with some more clear coat. Anyone got any other ideas?
Old Oct 19, 2003 | 12:29 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: DIY painted a lip, any way to make it more glossy/smooth? (alfaaay)
wet sanding has to come after any sort of paint application if you want it to look smooth. The problem is that you don't get as fine of a spray out of a paint can as you do an HVLP paint gun, so you get more of an orange peel look.
Old Oct 19, 2003 | 01:32 PM
alfaaay's Avatar
Default Re: DIY painted a lip, any way to make it more glossy/smooth? (PatrickGSR94)
hmmm... so what would you suggest? It does't look bad, but it definitely looks sprayed. I had a friend that had his whole car looking the same way because he took it to some paint shop that didn't wet sand, so I think I'm gonna give that a try next weekend.
Old Oct 19, 2003 | 05:22 PM
B U N M A N G O's Avatar
yea give wetsanding a try... 1000 grit, then 1500, then 2000... etc etc followed up by rubbing compound and a glaze.
Old Oct 19, 2003 | 08:27 PM
alfaaay's Avatar
Default Re: DIY painted a lip, any way to make it more glossy/smooth? (B U N M A N G O)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B U N M A N G O &raquo;</TD></TR><TR><TD CLASS="quote">yea give wetsanding a try... 1000 grit, then 1500, then 2000... etc etc followed up by rubbing compound and a glaze.</TD></TR></TABLE>
Where can I find rubbing compound and glaze? I don't think I've ever see what either of those look like.
Old Oct 19, 2003 | 09:08 PM
auto parts store... I'd suggest you buy 3M
Old Oct 19, 2003 | 10:32 PM
whoDAT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B U N M A N G O &raquo;</TD></TR><TR><TD CLASS="quote">I'd suggest you buy 3M</TD></TR></TABLE>
but imo, i don't think it's worth the time and effort when rocks and road debris is going to get the best of it.
Old Oct 20, 2003 | 01:46 PM
alfaaay's Avatar
Default Re: DIY painted a lip, any way to make it more glossy/smooth? (whoDAT)
Okay so here's a new question... should I wet sand, and spray more clear coat or just wet sand (clear coat is already on)?
Old Oct 20, 2003 | 02:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alfaaay &raquo;</TD></TR><TR><TD CLASS="quote">Okay so here's a new question... should I wet sand, and spray more clear coat or just wet sand (clear coat is already on)?</TD></TR></TABLE>
Wetsand and then buff, and see how you like it.
Old Oct 20, 2003 | 05:05 PM
Regal's Avatar
Ladies and gentlemen we are floating in space...
There are a bunch of threads about this. People have done their lips, sideskirts, and moldings, and they've all come out looking great
I don't have time to find the threads, but wetsanding wasn't part of the process at all.
Old Oct 20, 2003 | 05:52 PM
alfaaay's Avatar
Default Re: DIY painted a lip, any way to make it more glossy/smooth? (Regal)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Regal &raquo;</TD></TR><TR><TD CLASS="quote">There are a bunch of threads about this. People have done their lips, sideskirts, and moldings, and they've all come out looking great
I don't have time to find the threads, but wetsanding wasn't part of the process at all.</TD></TR></TABLE>
I searched around, and didn't get much. I followed the same DIY that I did when I did my side skirts, and the skirts came out hella good (I didn't wet sand then). I'm guessing that maybe it's because this is a bigger surface, or I didn't use enough clear coat and now I'm just trying to get opinions on how to remedy it.
Old Oct 20, 2003 | 06:15 PM
integ 1983's Avatar
Dude, wet sanding is a delicate procedure. I suggest that you read this article very carefully.
http://www.goodspeedmotoring.com/?page=sanding
Old Oct 20, 2003 | 07:12 PM
Default Re: (integ 1983)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integ 1983 &raquo;</TD></TR><TR><TD CLASS="quote">Dude, wet sanding is a delicate procedure. I suggest that you read this article very carefully.
http://www.goodspeedmotoring.com/?page=sanding</TD></TR></TABLE>
It isn't that big of a deal in this case, since he isn't doing his entire car. It's only his lip- if he screws up, he can just paint it again
blackcivic11
Paint and Body
Aug 1, 2009 01:49 PM
Zaraki
Paint and Body
May 21, 2008 03:24 PM
adobospoon
Paint and Body
Oct 27, 2007 12:53 AM
N0E5cape
Apr 8, 2002 09:54 AM
AK94GSR
Mar 5, 2002 03:43 PM
