JDM ITR steering wheel spacer?
Old Oct 19, 2003 | 12:23 AM
lanceh's Avatar
25 Year Member
Default JDM ITR steering wheel spacer?
i currently have a momo steering wheel with a momo hub and LTB quick release. with this setup the steering wheel is a good 3" or so further from the dash. this allows me to get my knees under the steering wheel for proper heal/toe driving.
does anyone know if there is a spacer that could be used to get the same results with a JDM ITR steering wheel?? when installed the steering wheel is just about the same distance as stock and won't work for me.
Old Oct 20, 2003 | 06:59 AM
lanceh's Avatar
25 Year Member
Default Re: JDM ITR steering wheel spacer? (lanceh)
no one has a thought?
Old Oct 20, 2003 | 07:21 AM
thk's Avatar
thk
Members Only
I can't imagine how it would work since ...
[hub] [spacer/quick release] [steering wheel] <---momo/aftermarket
[built in "hub" + JDM ITR steering wheel]
No place to put on a spacer.
Old Oct 20, 2003 | 08:22 AM
sackdz's Avatar
Default Re: JDM ITR steering wheel spacer? (thk)
Not possible without major modification.
Old Oct 20, 2003 | 08:34 AM
MattD@Stoptech's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanceh &raquo;</TD></TR><TR><TD CLASS="quote">i currently have a momo steering wheel with a momo hub and LTB quick release. with this setup the steering wheel is a good 3" or so further from the dash. this allows me to get my knees under the steering wheel for proper heal/toe driving.
does anyone know if there is a spacer that could be used to get the same results with a JDM ITR steering wheel?? when installed the steering wheel is just about the same distance as stock and won't work for me.</TD></TR></TABLE>
J00 need a leg "reducer"....
lanceh's Avatar
25 Year Member
Default Re: JDM ITR steering wheel spacer? (sackdz)
yeah, that's what i figured.
Old Oct 20, 2003 | 11:52 AM
lanceh's Avatar
25 Year Member
Default Re: JDM ITR steering wheel spacer? (El Pollo Diablo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by El Pollo Diablo &raquo;</TD></TR><TR><TD CLASS="quote">
yeah and you need stilts
Old Oct 20, 2003 | 12:11 PM
Chris N's Avatar
Lance,
Maybe when j00 get a bucket, with rails that let you sit lower....
then everything will be fo sheezy with your big knobby knees and the steering wheel?
Old Oct 20, 2003 | 02:49 PM
Dirt's Avatar
Lance, you sayin' your wheel combo is 3" too close to you?
I bought an SRR spacer for my Civic mess (Momo Corse/SRR spacer/Dino hub).
Old Oct 20, 2003 | 03:46 PM
Mario's Avatar
does anyone know if there is a spacer that could be used to get the same results with a JDM ITR steering wheel?? </TD></TR></TABLE>
Which version? SRS or non-SRS?
Old Oct 20, 2003 | 03:59 PM
splitime's Avatar
Default Re: JDM ITR steering wheel spacer? (Mario)
he's looking non-srs i believe.
Old Oct 20, 2003 | 04:12 PM
Mario's Avatar
Default Re: JDM ITR steering wheel spacer? (splitime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by splitime &raquo;</TD></TR><TR><TD CLASS="quote">he's looking non-srs i believe.</TD></TR></TABLE>
If that's the case. Fellow H-T member "SBE" has already done what you are wanting to do. He likes to sit so far back, that when he looks to the side he's peeking out through his quarter panel windows (gangster). Therefore he needed to extend the steering wheel closer to his driving position.
He made a custom billet adapter that is longer than the OEM hub it replaces.
So by that token, it's absolutely do-able.
Furthermore, I remember old time member Benjamin Tang saying the non-SRS hub is just like any other aftermarket hub in respect that it's removable & interchangeable. If that's so, you might be able to just add a hub extender.
Like this 30mm spacer.
gravity73
Northwest
Aug 14, 2010 02:26 PM
v t e c 2 3
Jan 20, 2005 10:27 AM
