how much is a decent price for this used amp?
what is a decent price for this amp??
and is it any good at all?
http://www.mtx.com/caraudio/ar...x.cfm
The front and rear crossovers are 18dB/octave, continuously variable between 50Hz and 200Hz high pass or low pass, giving you several options in setting up your system.
The new symmetrical power supply allows for better thermal distribution.
The "sum output" jacks on the four-channel amplifiers provide a line level summed output of the right front/right rear and left front/left rear input signals. This output is typically used to drive an external subwoofer amplifier.
RMS Power measured at 12.5 Volts DC:
25 Watts x 4 into a 4 Ohm load with less than 0.1% Thd+N
50 Watts x 4 into a 2 Ohm load with less than 0.3% Thd+N
100 Watts bridged x 2 into a 4 Ohm load with less than 0.3% Thd+N
Dynamic Power (IHF-202 Std) measured at 14.4 Volts DC
55 Watts x 4 into a 4 Ohm load
100 Watts x 4 into a 2 Ohm load
200 Watts bridged x 2 into a 4 Ohm load
Signal to Noise Ratio:
> or = 110dB A-Weighted
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Thunder EQ:
Variable Bass Boost (0-18dB) centered at 40Hz
Crossover:
Variable 50Hz to 200Hz, 18dB/Octave, High Pass or Low Pass Configurable
Dimensions:
11" x 9" x 2" (27.9cm x 22.8cm x 5cm)
12-1/4" x 9" x 2" (31.1cm x 22.8cm x 5cm) Including IsoFeet(TM)
Damping Factor:
>200
Frequency Response:
20Hz-20kHz±0.25dB
Thunder EQ:
Crossover:
Dimensions:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RiceRacist »</TD></TR><TR><TD CLASS="quote">60-75 off ebay</TD></TR></TABLE>
Yup!
Yup!
