Headers.. 90-93 compatible with 94-96???
Old Oct 18, 2003 | 10:15 PM
CityHunt3r's Avatar
Default Headers.. 90-93 compatible with 94-96???
i have a honda accord 90.. with (supposedly) a 95 accord motor in it.. i need new headers and i dont know what year headers i should but it for.. 90-93 or 94-98.. im not sure what the diferance is can anyone help.. help sitinguish wither or not i have in fact a 95 honda accord motor or not or does it matter???
Old Oct 19, 2003 | 09:23 AM
Superdragr45's Avatar
Default Re: Headers.. 90-93 compatible with 94-96??? (CityHunt3r)
u should buy the header that is compatible with the engine........and, u may have to lengthen/shorten ur exhaust because headers are different lengths........
Old Oct 19, 2003 | 10:25 AM
NathanMorris's Avatar
Default Re: Headers.. 90-93 compatible with 94-96??? (Superdragr45)
negative, I believe it's like this: 4th gen: o o o o ....5th gen O OO O for the port patern. Also, it'd defeat the purpose, as the tuned lengths/etc for the 4th will be diff. than the 5th
- Nathan
Old Oct 19, 2003 | 10:58 AM
twkdCD595's Avatar
Default Re: Headers.. 90-93 compatible with 94-96??? (92Lx)
depending on which f22 you get the header from.
a f22b1 does have a port design like 0 00 0, and not the 0 0 0 0.
check your port deisgn and compare with some pictures of other f22's online.
Old Oct 19, 2003 | 01:43 PM
iam7head's Avatar
Default Re: Headers.. 90-93 compatible with 94-96??? (twkdCD595)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twkdCD595 &raquo;</TD></TR><TR><TD CLASS="quote">depending on which f22 you get the header from.
check your port deisgn and compare with some pictures of other f22's online.</TD></TR></TABLE>
yeppie
Old Oct 20, 2003 | 09:27 AM
Bantam's Avatar
2nd Coolest Person in DFW
cant you just look at the block stamp to determine what engine you have?
<U>http://www.imagestation.com/picture/sraid53/p40e3fcfd49d409b7fc336e569b7efc58/fc8c423b.jpg.orig.jpg</U>
thats a picture of my block stamp. if it has the 95 accord motor in it, it will either say f22b1 (EX VTEC) or f22b2(other models)
if it says f22a1, you need a header for a 90-93 ex, if it says f22a4, you want the header for the DX, LX, etc, though they might be the same...thats not my deal...good luck
in reference to the following post:
mistake corected so i dont look like a tool
Modified by tharptroy at 9:40 PM 10/20/2003
Old Oct 20, 2003 | 10:28 AM
twkdCD595's Avatar
Default Re: Headers.. 90-93 compatible with 94-96??? (tharptroy)
the ex vtec 5th gen is the f22b1.... not b2
mase08
Apr 16, 2010 07:21 AM
PreludePhill
Dec 30, 2004 08:13 PM
Ludeboi
Nov 10, 2002 05:45 PM
sloaccord96
May 17, 2002 12:54 PM
sloaccord96
May 17, 2002 06:35 AM
