Should I wait until the first oil change to install a Type R Valve Cover?
Old Sep 2, 2001 | 08:07 AM
GSR2001's Avatar
Default Should I wait until the first oil change to install a Type R Valve Cover?
Well, I just got a brand new Type R Valve Cover . My car only has about 2,500 miles on it. When the car reaches 3,000 miles I'm changing the oil. Should I wait until that time because of the break-in oil to change the Valve Cover or does it matters? Thanks
Old Sep 2, 2001 | 08:55 AM
GSR2001's Avatar
Default Re: Should I wait until the first oil change to install a Type R Valve Cover? (GSR2001)
Anyone????????
Old Sep 2, 2001 | 09:26 AM
non-VTEC's Avatar
it doesnt matter at all...........go ahead and put it on right now!!
Old Sep 2, 2001 | 09:36 AM
B2FiNiTY's Avatar
Doesn't matter!!!
Old Sep 2, 2001 | 10:56 AM
LostGsr's Avatar
Break in period and changing the valve has nothing to do with each other. Go ahead and change it now. But if it was me I would swap the valve cover when you change the oil because while you are waiting for the old oil to drip completely out you can use that time to swap the cover.
[Modified by LostGsr, 11:58 AM 9/2/2001]
Old Sep 2, 2001 | 11:07 AM
PROFILES2000's Avatar
Default Re: Should I wait until the first oil change to install a Type R Valve Cover? (LostGsr)
becarefull tightining all the bolts
Old Sep 2, 2001 | 03:47 PM
GSR2001's Avatar
Default Re: Should I wait until the first oil change to install a Type R Valve Cover? (ProfileGsR)
Somebody posted that you should torque them to 7.2 Ft/lbs.
Old Sep 2, 2001 | 04:07 PM
137's Avatar
137
torque the cover down to helms spec or you will snap the **** out of the bolts that hold it on, trust me.
Old Sep 2, 2001 | 08:14 PM
D-SPEED's Avatar
Default Re: Should I wait until the first oil change to install a Type R Valve Cover? (137)
i would think you want to change you first tank of oil before 3000 miles... my moms new scoob wrx has it changed after 1k....
Old Sep 3, 2001 | 07:48 AM
1fastGSR's Avatar
New User
Default Re: Should I wait until the first oil change to install a Type R Valve Cover? (D-SPEED)
how many HP does the red valve cover give?
Old Sep 3, 2001 | 08:14 AM
GSR2001's Avatar
Default Re: Should I wait until the first oil change to install a Type R Valve Cover? (1fastGSR)
Well, I don't want to be rude so I'm not going to act like an *******. But a like it for looks, I know it doesn't give any HP but for show it will give you points. And yes I'm also working on buying a Header, Sway bars and go fast items for my car.
P.S. I also got the OEM Body kit, no HP but it looks damn good
Old Sep 3, 2001 | 10:09 AM
1fastGSR's Avatar
New User
I am j/k. I know it does look nice!
PhunekyPhish
18
May 13, 2014 02:47 AM
vtec.dc2
Sep 10, 2003 10:08 PM
J337_UNIT
Sep 4, 2003 12:47 PM
lildrgn2.0
Nov 8, 2002 01:04 PM
