Want to Buy Want to Trade/Want to Buy
WTB: 00-01 LS ECU Stick
Old Oct 18, 2003 | 10:48 AM
Mr.DC2TurBo's Avatar
Default WTB: 00-01 LS ECU Stick
need obd2b ecu for LS stick.
Old Oct 18, 2003 | 01:28 PM
Default Re: WTB: 00-01 LS ECU Stick (Mr.DC2TurBo)
hook me up guys
Old Oct 18, 2003 | 01:41 PM
dose's Avatar
IM sent
Old Oct 18, 2003 | 02:29 PM
C uR eX's Avatar
i got an obd 2 LS ecu but is there a certain # to the ecu that tell you it a obd2b? or a?
Old Oct 18, 2003 | 02:42 PM
Default Re: WTB: 00-01 LS ECU Stick (C uR eX)
look at the plugs, do you see pins in the first 3 plug and no pins in the 4th or do you see pins in the 1st and no pins in the 2nd and pins in the 3rd and 4th plugs?
Old Oct 19, 2003 | 09:30 AM
C uR eX's Avatar
pins area located in the 1st; 3rd; & 4th.
empty in the 2nd.
Old Oct 19, 2003 | 10:19 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C uR eX &raquo;</TD></TR><TR><TD CLASS="quote">pins area located in the 1st; 3rd; & 4th.
empty in the 2nd.</TD></TR></TABLE>
you have obd2a
Old Oct 19, 2003 | 10:35 AM
C uR eX's Avatar
oh ok soory then but here try this:
https://honda-tech.com/zerothread?id=633893
Old Oct 19, 2003 | 01:59 PM
thanks, i saw that too and his is obd2a also.
Old Oct 19, 2003 | 02:27 PM
PHiZ's Avatar
ECU has immobilizer after 00. So that is important to consider.
-PHiZ
Old Oct 19, 2003 | 08:16 PM
Default Re: WTB: 00-01 LS ECU Stick (PHiZ)
so wat does that mean.. I can't use other ecu if i'm obd2b?
Old Oct 19, 2003 | 08:36 PM
PHiZ's Avatar
Basically, yes. The dealer might be able to do something for you if you have fully documented paperwork on the ecu, dunno.
do some searching on immobilizer.
-PHiZ
iblewmyrmotor
Northeast (Sales)
Nov 13, 2007 03:15 AM
prestonpark
Sep 14, 2004 10:02 PM
wm5holla
Sep 23, 2003 01:20 PM
bubblebackinSI
Aug 26, 2003 04:38 PM
HondaGuRu
Jul 16, 2003 09:49 AM
00, 01, ecu, ls
