How about RC 310 injectors?
Old Oct 18, 2003 | 10:08 AM
CHRIS 1.8's Avatar
Default How about RC 310 injectors?
I found a used set of RC 310 injectors that I may buy and I was wondering if it would just plug right in on my OBD0 setup with PR3 Mugen program?
I have a LS/VTEC with oversized ITR pistons, ported B16 head with Skunk2 Stage 2 cams.
Old Oct 18, 2003 | 11:53 AM
Ruby Civic's Avatar
Default Re: How about RC 310 injectors? (CHRIS 1.8)
well you can but will run rich and will have to subtract off fuel on vafc at idle and bottom end of the tach scale - or dyno with air-fuel ratio capability
Old Oct 18, 2003 | 12:50 PM
CHRIS 1.8's Avatar
Default Re: How about RC 310 injectors? (Ruby Civic)
So it will hook up to my existing harness where my stock injectors are at now and plug right in just fine?
Old Oct 18, 2003 | 01:10 PM
Mach slo's Avatar
Your ok. The way that the obd0 ecu's open the injectors, it can run both high impedence and saturate injectors.
Old Oct 18, 2003 | 03:56 PM
Ruby Civic's Avatar
Default Re: How about RC 310 injectors? (Mach slo)
yes also, just know that you will be running rich esp at idle and have to cone those puppies down
Old Oct 18, 2003 | 07:21 PM
EF_LSVtec's Avatar
FYI, your stock injectors (nonobd) are peak and hold...RC310's are saturated. I don't think they're plug and play.
Old Oct 18, 2003 | 10:49 PM
kill bill's Avatar
Default Re: How about RC 310 injectors? (EF_LSVtec)
off the subject chris, but did u ever get your money back from UPGRADE, for ripping you off on the skunk cams that were really stock b16 cams? or at least a retalliation attempt?
Old Oct 18, 2003 | 11:46 PM
CHRIS 1.8's Avatar
Default Re: How about RC 310 injectors? (kill bill)
Nope, I'm over it. We all have are loses and just move on...
Old Oct 21, 2003 | 12:03 AM
kill bill's Avatar
wow. i dont know many people who just move on from 600+ dollar losses...bummer.
Old Oct 21, 2003 | 11:28 AM
King Tut33's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_LSVtec &raquo;</TD></TR><TR><TD CLASS="quote">FYI, your stock injectors (nonobd) are peak and hold...RC310's are saturated. I don't think they're plug and play.</TD></TR></TABLE>
Incorrect. RC sells both types for 310cc. Mine bolted right in.
01typerboi
Dec 23, 2010 12:42 PM
civacman
May 15, 2008 10:37 AM
AllMotorDA9
Nov 23, 2004 09:30 AM
J-Spec EG
Apr 27, 2004 05:40 AM
1hotintegra
Feb 29, 2004 10:11 AM
