JDM DC5 OEM HID question....
I was wondering how much does these usually go for? Where can they be found? Also, i am assuming is pretty much striaght plug and play.....if not, what should i look for? Will the output beam pattern be better than the stock housing with a HID kit in it?
Thanks
Thanks
try xenondepot.com kits run about 500 bux get the 4100 kit unless your a rice boy, in that case get the 9000 kit LOL Good luck with your purchase
INstallation is pretty straight forward. If you want genuine HIDs you can order 2002 NSX HID bulb ,ballast...etc. they will fit to the JDM HID housing. NSX uses the same ballast as DC-5.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AJ PwR »</TD></TR><TR><TD CLASS="quote">INstallation is pretty straight forward. If you want genuine HIDs you can order 2002 NSX HID bulb ,ballast...etc. they will fit to the JDM HID housing. NSX uses the same ballast as DC-5.</TD></TR></TABLE>
But what about the HID Reflector compared to the Halogen reflector?
Langsta
19
Jun 22, 2016 08:52 PM
gdrum
Jan 31, 2006 08:22 PM
