need advice on all motor upgrade
Old Oct 18, 2003 | 05:46 AM
civicVX's Avatar
Default need advice on all motor upgrade
looking for any help. looking to upgrade my b16b. i know i can use a b18c rotating assembly to get 1.8 displacement. my question is can i use a 1.8-2.0 stroker in my block without any clearance issues. i am under the impression that a b16b block is a destroked b18c5 block. is this correct and can anyone help me with info. thats for you help.
Old Oct 18, 2003 | 07:18 AM
dwn-shift's Avatar
Default Re: need advice on all motor upgrade (civicVX)
The b16 block has a shorter deck height then the b18 and b20 blocks. If it didnt people would just simply get b16 blocks and throw gsr or ls rotating assemblies in there and ahve a 1.8. If you already have a b16 motor, you can pick up a ls shorty and put togahter a decent ls/vtec. Or get a gsr block slap on the b16 head and you then have yourself a poor mans R.
mike
Old Oct 18, 2003 | 07:56 AM
genius's Avatar
Default Re: need advice on all motor upgrade (dwn-shift)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwn-shift &raquo;</TD></TR><TR><TD CLASS="quote">The b16 block has a shorter deck height then the b18 and b20 blocks. If it didnt people would just simply get b16 blocks and throw gsr or ls rotating assemblies in there and ahve a 1.8. If you already have a b16 motor, you can pick up a ls shorty and put togahter a decent ls/vtec. Or get a gsr block slap on the b16 head and you then have yourself a poor mans R.
mike</TD></TR></TABLE>
he has a b16b...which is a destroked b18c
it has the deck height of b18c not b16.
Old Oct 18, 2003 | 07:59 AM
genius's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicVX &raquo;</TD></TR><TR><TD CLASS="quote">looking for any help. looking to upgrade my b16b. i know i can use a b18c rotating assembly to get 1.8 displacement. my question is can i use a 1.8-2.0 stroker in my block without any clearance issues. i am under the impression that a b16b block is a destroked b18c5 block. is this correct and can anyone help me with info. thats for you help.</TD></TR></TABLE>
you can use any crank ls,gsr or any stroker cranks available for b18 without clearance issues as long as you use corresponding rods.
Old Oct 18, 2003 | 08:07 AM
civicVX's Avatar
Default Re: need advice on all motor upgrade (genius)
thanks guys.
Old Oct 18, 2003 | 08:32 AM
dwn-shift's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by genius &raquo;</TD></TR><TR><TD CLASS="quote">
sorry wasnt paying attention, on me... Is it worth ripping that motor apart then, that would be my question. I figure it would be cheaper to just pick up another block.
bosna1
Nov 5, 2008 07:06 AM
boosted92hatch
May 27, 2006 08:31 PM
egeeb16
Mar 2, 2006 07:37 AM
Monochild
May 31, 2005 05:11 PM
fernancivic
Sep 29, 2003 02:37 PM
