gurlfriends ep3 lowering...suggestiong...
Old Oct 17, 2003 | 04:45 PM
al3e's Avatar
Default gurlfriends ep3 lowering...suggestiong...
what up. my girl just got a new si... she wants to lower it....she wants it low...she thinks its cool to be able to adjust the height... but i think she wants a good ride still...and I wouldnt mind spending 200 bucks...but donno about anything like 1000 dallaz. im kinda low on doh ... so maybe some....cheaper ones...?? or just get racining lowering springs...
gimme your opnion...
Old Oct 17, 2003 | 08:14 PM
civicvtec1ps's Avatar
Default Re: gurlfriends ep3 lowering...suggestiong... (al3e)
its up to you. you could get gc or skunk2 coilovers for around 300. and you can put them on stock shocks until you need to replace them eventually. just keep in mind. whenever you adjust height of the car. you will need realignment
Old Oct 17, 2003 | 10:22 PM
Mr. Choi's Avatar
New User
if you go too low ride will be like ****. your struts doesnt have enough travel in them
so you cant go too low. plus if you get after market springs the ride will be stiffer so
you cant really get a "good ride" IMO you need to tell your girl not to become a ricer
and get things done correctly. correctly as in get a coilover kit.
Old Oct 18, 2003 | 01:59 AM
Unit-X's Avatar
Default Re: gurlfriends ep3 lowering...suggestiong... (Mr. Choi)
tell your girl if she's going to drop her car hella low, she better learn to drive it if not shes going to be like most girls i know with dropped cars scratching, hitting, and scraping every corner and bump.
Old Oct 18, 2003 | 09:06 AM
al3e's Avatar
Default Re: gurlfriends ep3 lowering...suggestiong... (Unit-X)
yeah ive been showin her the little things. goin slow around dips and what not... yeah i donno might just get some used or really cheap coilover kit... dont wanna be loaning for her coiolvers im still payin off my car... ha
thanks
Old Oct 18, 2003 | 05:53 PM
Peking's Avatar
A few of us have gone with H&R Race springs with stock shocks, not a prob. just know that the stock shocks will have a much shorter life so prepare to buy new shocks. Got my springs from http://www.showstoppersusa.com/ got it with the camber kit to, springs drop you 2" all around so camber adjustment is needed.
Check this for some info http://www.ephatch.com/forum/s...21274
You can check that thread at http://www.ephatch.com/forum/s...17730
Hope this helps some.
Old Oct 18, 2003 | 09:30 PM
.::miLan's Avatar
Default Re: gurlfriends ep3 lowering...suggestiong... (Peking)
There's no point dropping your car really really low. Then you've got to be more careful that you don't bottom out and hit your oil pan. I would just get some Sport or Racing springs and a camber kit - that is, until u need new dampers...
Old Oct 19, 2003 | 03:10 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by al3e &raquo;</TD></TR><TR><TD CLASS="quote">what up. my girl just got a new si... she wants to lower it....she wants it low...she thinks its cool to be able to adjust the height... but i think she wants a good ride still...and I wouldnt mind spending 200 bucks...but donno about anything like 1000 dallaz. im kinda low on doh ... so maybe some....cheaper ones...?? or just get racining lowering springs...
gimme your opnion...</TD></TR></TABLE>
Ground Control coilovers with custom spring rates and Koni yellow struts. This setup should last for as long as you own the car. Ride height is fully adjustable, you can specify what spring rates you want (you can optimize the springs for either handling or comfortable ride, whichever you want), and Koni yellows are an excellent single-adjustable strut with a lifetime warranty. Do not reuse stock struts. If you need help choosing what spring rates are right for you just give GC a call and ask them what they would recommend for your needs. Also if you are unhappy with the spring rates you get, you can just order new Eibach ERS springs from Ground Control with different rates (I believe they come in 25 lb/in increments) and swap them in place of your old springs.
Do it right the first time or don't bother doing it at all.
Old Oct 19, 2003 | 04:24 PM
1abSi's Avatar
wowa i am confused...only person i know of in GA running 225's on 15' oz's on a black ep is chunky??????you switch you handle, or are you using someone elses car...would be crazy for two people to have that SAME setup that close to eachother
Old Oct 19, 2003 | 04:32 PM
Graham's Avatar
Peking ... I love your rims Great choice. I really wanted the 15" superleggeras, but went with the Konig Heliums in bronze due to budget ... nothing wrong with lightweight 15" rims on the EP ... looks great.
Oh - I went with 205/55R15 EVS100s ... I think for my next set I'll try 225s ...
Cheers,
Graham
Old Oct 19, 2003 | 06:43 PM
chunky's Avatar
Default Re: gurlfriends ep3 lowering...suggestiong... (Graham)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Graham &raquo;</TD></TR><TR><TD CLASS="quote">Peking ... I love your rims Great choice. I really wanted the 15" superleggeras, but went with the Konig Heliums in bronze due to budget ... nothing wrong with lightweight 15" rims on the EP ... looks great.
Cheers,
Graham</TD></TR></TABLE>
actually, those are pics of my car. If you look in the thread that peking linked (the 2nd thread) you'll see where he linked the pictures from (my spring install thread on ephatch.com)
see my sig for a pic of my car when clean. =P
And wassup jon, linking my pics w/o giving credit - it's a good thing I know you f00.
oh, and I'll add that the H&R springs work quite well with stock shocks. stiffer, but not too stiff. Stock shocks have 57,000 miles on them with 10,000 miles on the H&R springs.
I do want new dampers, but the Koni setup is unacceptable to me. So i'll wait for a better solution or until my stock shocks give out and force me to buy some coilovers.
Old Oct 20, 2003 | 09:39 AM
stephenSI's Avatar
Default Re: gurlfriends ep3 lowering...suggestiong... (chunky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunky &raquo;</TD></TR><TR><TD CLASS="quote">
Great looking car. I love the look of the 15 inch superleggeras with W I D E wheels.
Old Oct 25, 2003 | 04:58 AM
Peking's Avatar
Default Re: gurlfriends ep3 lowering...suggestiong... (stephenSI)
By bad Chunky, I thought I put your name in the post.
Old Oct 25, 2003 | 07:12 AM
14eight's Avatar
Halfass Suspension = Halfass Ride
another way of saying that is
Shitty Suspension = Shitty ride
Do it right the first time, your buying suspension for a new car, if you were buying suspension for an old beat up civic then i would say who cares but why buy an expensive car and then put cheap junky suspenesion in it? oh well The only advice i can give is DO IT RIGHT THE FIRST TIME!!! youll be very happy you took that advice trust me!
Old Oct 25, 2003 | 07:44 AM
Peking's Avatar
Default Re: gurlfriends ep3 lowering...suggestiong... (14eight)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 14eight &raquo;</TD></TR><TR><TD CLASS="quote">Halfass Suspension = Halfass Ride
Do it right the first time, your buying suspension for a new car, if you were buying suspension for an old beat up civic then i would say who cares but why buy an expensive car and then put cheap junky suspenesion in it? oh well The only advice i can give is DO IT RIGHT THE FIRST TIME!!! youll be very happy you took that advice trust me! </TD></TR></TABLE>
Who's halfassing? And I agree with you, doing it right the first time with good parts is key to having a great ride.
Old Oct 25, 2003 | 08:09 AM
14eight's Avatar
the original poster, he said he might just get some junky suspension for his girls ep3. not a good idea in my book
Old Oct 25, 2003 | 04:27 PM
Peking's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 14eight &raquo;</TD></TR><TR><TD CLASS="quote">the original poster, he said he might just get some junky suspension for his girls ep3. not a good idea in my book</TD></TR></TABLE>
Oh ya, by fault. I agree with you, it's a very bad idea.
Old Oct 25, 2003 | 07:26 PM
chunky's Avatar
I agree. i.e. do NOT get neuspeed race springs, they will be bouncy & wear your shocks out in less than a year garanteed.
get some springs that are designed to work with the stock shocks, h&r sport springs, eibach pro-kit & sportline, progress. and get a camber kit for anything that is over 1.5" drop. You can get away with a 2.0" drop w/o a camber kit, but it's worth the money to keep the camber in spec.
Old Oct 26, 2003 | 07:24 AM
I am USDM's Avatar
ive got tein s. tech springs on mine, been on for about 7k miles, its a great ride, nice ride height, and nice weight distribution too IMO. got them from showstoppers, great place to deal with and i got them for 139 shipped, not sure what they are now, but im sure theyre still inexpensive. ill try to post some pics sometime today.
Modified by ProdigyGTI2k at 12:46 PM 10/26/2003
projected3
26
Oct 2, 2010 10:08 AM
cd5tuner615
May 10, 2009 12:31 PM
mikeaitken
Apr 10, 2007 05:04 PM
hondafrk505
27
Jul 1, 2006 01:59 PM
SilverAccord
Jul 27, 2001 04:31 PM
