CRX / EF Civic FAQs Updated!
Old Oct 17, 2003 | 03:30 PM
crxforum's Avatar
Default CRX / EF Civic FAQs Updated!
I got alot of IMs in the last few days wondering what I had in the FAQ so far. So here is a list for the EF Civic and CRXs. If you want to see them and the others go to http://www.romomoto.com/faq/faq.htm
<U>Engine: </U>
ZC Swap Info
JDM Engines For Sale
How to Identify B16A1 and B16A2
B16A Information
How to Swap a ZC Engine
How to Swap a Z6 Y8 into a 4th Generation Civic
JDM B16A Information and 4th Generation ECU Pin Outs
How to Swap a Z6 Head Onto Your A6
More Information On Swapping D16Z6 into an EF
D15 OBD1 SOHC VTEC Mini Me Swap Information
B16A Secondary o2 Sensor Wiring and Vacuum Diagrams
DPFI to MPFI Fuel Injector Swap Guide
SOHC Upgrades (Ongoing Information)
How VTEC Works
<U>Appearance:</U>
JDM Appearance Parts
OEM Honda Engine Parts
CRX and 4th Generation Civic Appearance Mods
OEM Honda Parts
<U>Electrical:</U>
ECU Tuning and ECU Info
SiR Gauge Cluster Installation
4th Generation Civic SiR Gauge Cluster Installation
EF ECU Codes and Troubleshooting
How to Check ECU / Engine Codes
How to Chip a 92-95 Civic ECU
Will CRX Taillights fit a Civic
Will Civic Taillights fit a CRX
<U>Mechanical:</U>
Axel Replacement
Camshaft Test
LS 5th Gear Install Guide JDM B16 S1
How to do a Rear Disc Swap
EF Steering Rack Removal
How to Extend Shock Travel
<U>Exterior / Interior: </U>
How to Rebuild Your Sunroof
How to Use Fiberglass
How to Make Homemade Air Splitters / Canards
Will a CRX Bumper fit a Civic Hatchback or Sedan
Will a Civic Hatchback or Sedan Bumper fit a CRX
<U>Other / Specs: </U>
JDM Parts that You Can Swap Into an EF
Chassis Codes and Differences Between JDM EFs and USDM EFs
Differences in 2nd Generation CRXs
I hope that clears things up. I didnt post this in the FAQ post because it was not getting too many views or replies. Please if you have a link in your favorites or something that will help us out please post a link in here or in the FAQ section. Dont write the specs, copy the link. It makes my job a hell of alot easier.
Thanks
CRX Forum
Old Oct 17, 2003 | 03:33 PM
bryant's Avatar
Default Re: CRX / EF Civic FAQs Updated! (crxforum)
Sweet, its finally happening. I just need to find my:
How to: OEM Acura TL HID's into Stock headlights thread
and make my new
How to: JDM Fogs on USDM Front end.
Old Oct 17, 2003 | 05:13 PM
senpai's Avatar
Default Re: CRX / EF Civic FAQs Updated! (Bryant)
I had similar idea
trampuscool
Dec 20, 2010 08:16 AM
honda zc
18
Aug 19, 2010 02:14 AM
benmyfriend
Oct 31, 2005 03:43 AM
fresh99si
Nov 6, 2003 12:50 PM
