GSR with ITR pistons Q?
Old Oct 17, 2003 | 02:51 PM
Team 4's Avatar
Default GSR with ITR pistons Q?
Yes, did a search.
I can get a good deal on them, and since I burnt the #2 exhaust valve...
My question is, how much of a jump in power will I see with just pistons on a USDM GSR? Noticable? Also, how much tuning is required?
Old Oct 17, 2003 | 03:05 PM
thegrinch's Avatar
Default Re: GSR with ITR pistons Q? (REVHARD_EF)
you will probably see about 10whp... that is about it . That is what was realized on the setup that I did a long time ago.
Old Oct 17, 2003 | 03:29 PM
Mr Hammond's Avatar
a/k/a Jomo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by REVHARD_EF &raquo;</TD></TR><TR><TD CLASS="quote">Yes, did a search.</TD></TR></TABLE>
If you did you would have found the answer in one of the 18 recent topics I got by searching. Compression will be around 11.35:1. When tuned should see a decent gain, maybe double digits.
Old Oct 17, 2003 | 03:46 PM
howl's Avatar
have you thought about getting the ctr pistons instead? they're pretty cheap and you'll get more hp than the itr pistons. compression will be around "12". (it could be a little more or a little less depending on headgasket and the condition of your head)
Old Oct 18, 2003 | 10:15 AM
Team 4's Avatar
Default Re: GSR with ITR pistons Q? (pr0ns74r)
I thought about CTR's, but at 12.4:1 it's just too high. I don't have gears or injectors and I'm limited to an FPR for tuning.
Thanks for your input guys.
stonet149
12
Nov 2, 2008 09:29 PM
Mikes2000civicsi
Jan 10, 2007 10:39 AM
usdmblackcivic
Jun 19, 2006 06:51 PM
raphael
May 5, 2006 10:46 PM
siis2fast
Aug 11, 2004 05:44 PM
