CRX front Bumper on EF 90 civic
Old Oct 17, 2003 | 01:26 PM
rags2riches's Avatar
Default CRX front Bumper on EF 90 civic
Im wondering if a 90 CRX bumper will fit on my 90 civic hatchback,
I have just added the crx seats/dash/heatercontrols and want the rest of the crx front end,
if I purchase the fenders/bumper/corner lamps will this fit .....
I need to know for sure because all that is gonna cost me a good $300-400...
thankyou
Old Oct 17, 2003 | 02:17 PM
hybridbmw's Avatar
Default Re: CRX front Bumper on EF 90 civic (rags2riches)
I know you will definately need the fenders, corner lights, bumper, and hood. I'm not sure about the headlights, but i believe they are the same. The crx and civic bumpers are different, the civic bumper uses a filler peice inbetween the hood and bumper where the crx doesnt.
Old Oct 17, 2003 | 02:51 PM
d357r0y's Avatar
Default Re: CRX front Bumper on EF 90 civic (speedaholic)
You will only need the fenders and bumper.. the hoods are the same.
The trim on the side of the crx fenders is different than the hatch so in order to make it look "right" you will have to do some cutting / welding. I am about to do this conversion myself and recently asked these same questions.
Old Oct 17, 2003 | 03:25 PM
bryant's Avatar
Default Re: CRX front Bumper on EF 90 civic (d357r0y)
I have seen the JDM CRX front on a hatch. So I am sure it will work. Just depends how much you want to get into it.
Old Oct 17, 2003 | 03:32 PM
crxforum's Avatar
Default Re: CRX front Bumper on EF 90 civic (Bryant)
http://www.romomoto.com/faq/EF/efbumper.htm
CRX Forum
Old Oct 17, 2003 | 04:02 PM
Mugen Dom's Avatar
Default Re: CRX front Bumper on EF 90 civic (crxforum)
also the bumper mounts would need to be changed possibly welded onto the hatch....the fenders would need to be cut in half welded to the hatch lower half its alot of bs for a crx front end
Old Oct 17, 2003 | 08:00 PM
keithg's Avatar
I have seen this done before. I am pretty certain you use the 90-91 civic hb hood and headlights(same as crx on these parts) and the 90-91 crx bumper with bumper brackets, fenders and side markers. The trick is to marry crx upper fenders with civic hb lower fenders by joining them together behind the body side molding. The car I saw, the fenders were overlapped and pop riveted behind the molding, the overlap was hardly noticeable.
sazdasl
Mar 20, 2007 04:23 AM
jeremiahs90civic
Aug 8, 2005 01:18 AM
s2kkk
May 25, 2004 07:19 PM
tunerx
Sep 30, 2002 01:41 PM
importneeds
Dec 20, 2001 07:08 PM
