5th Gen Clusters: 2 door and 4 door
Is there a difference between 2 door and 4 door clusters for a 5th gen?
I noticed on a 4 door, there are 4 door ajar lights, but I'm not sure if 2 doors use the same cluster and only uses 2 of the 2 lights, or it has a completely different cluster?
Thanks
Thanks
sorry if I phrased the question bad.. here's another attempt: :-)
Does 2 door use the exact same instrument cluster as a 4 door?
if you use a 2dr cluster in a 4 door the only problem will be that the two rear doors will not show on the cluster and the dome light will not turn on they are open either.
trust me, i know
trust me, i know
Then that means 2 doors and 4 doors DO NOT use the same cluster!?
This is what I'm trying to verify, if they use the same clusters then all clusters should have front and rear door lights, just that 2 doors don't use the rear ones.
Does anyone know for sure?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KGAccord »</TD></TR><TR><TD CLASS="quote">if you use a 2dr cluster in a 4 door the only problem will be that the two rear doors will not show on the cluster and the dome light will not turn on they are open either.
trust me, i know
trust me, i know
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stony TSi »</TD></TR><TR><TD CLASS="quote">Then that means 2 doors and 4 doors DO NOT use the same cluster!?
they are different,like i said i know for a reason. i have a 2dr cluster in a 4dr, the shop that did my 5sp swap didn't think about that i guess.
4DRmafia
10
May 29, 2004 07:46 PM
