1-2k rpm laggs
most likely egr ports are restricted/clogged
1800-2200 rpm engine will shudder a little bit...
refer to honda tsb #98-074 hesitation or stumble 90-93 accord
Modified by solo2slocivic at 8:40 AM 10/19/2003
the egr only recirculates spent fuel exhaust back into the intake to be used as a inert gas in combustion for reduced emissions and combustion temperatures... I dont think it would affect the car in the way you suggest.
also it should also trip a mil/ cel code if faulty itself.
whats the condition and maintence routine been like on this engine, been rode hard and put away wet?
Interesting, my 93 Accord does the same thing. Stumbles between 1-2K rpms only when warm. Replaced distributor assembly, cap, rotor, plugs, plug wires as part of maintenance/failure within past 3K miles and problem remains. At least I've got something to look at now!
Modified by typer_801 at 3:21 PM 1/19/2004
realprore
Feb 7, 2016 09:51 AM
plus1
Oct 27, 2004 11:07 AM
honda94vtec
Jul 10, 2002 05:26 AM
