Safe Rev Limiter
i am reprogramming my P28 ECU and need to know what would a safe rev limiter be. i have ITR inner/outer springs on my gsr (exh side only). stock gsr retainers and valves. thinking about getting either ITR or Skunk2 cams. anyone info would be of help. thanks
jeff
jeff
Banned
From: at last finally back to sweet home, sunny north cali, usa
FWIW, I ran ITR springs + crower ti retainers in my car for some 30k miles. Rev limit 9000-9200 (hondata). if you're on CTR/ITR cams torque will drop off sharply after 8500 rpm. i switch to skunk2 cams recently (from CTR) and it pulls strong to 9200 rpm. but i switched the inner springs to portflows because i also have a set of toda b's to play with later.
you are safe to 9000 rpm if you have ti retainers.
Banned
hmm actually please clarify your springs again. you have ITR dual intake valve springs and you moved the old GSR dual intake springs to the exhaust side? or something else? GSR's dual intake springs is identicle to ITR's dual ex. springs (same part #'s).
i should also note that back in 1999 i was running the prototype skunk2 cams on stock b16a valve springs (dual intake, single exhaust) with no problem. took it occasionally to 8800 rpm back then. it works because of the ramp profile. just the lift and duration doesn't tell the whole story.
[Modified by frank@b16a.com, 10:36 AM 9/1/2001]
screaminvtec
13
Jul 23, 2005 10:50 AM
boostin4door
May 16, 2005 06:48 AM
StinkyTofu
Feb 8, 2002 10:17 AM
ninjaman
Jul 17, 2001 05:24 PM
