nj peeps, help w/ my kenwood
I have one of those kenwood mask receivers, its currently off my car but I don't think its broken. I took it off from my old car n it was working perfectly, I've tried to put it back on & it doesn't fully function......I hear somethin but it doesn't flip back up....(mask feature)
Is there anybody here that could take a look at it for me to see what's up with it.....if i can fix it if its broken. Thanks in advance.
-Jun
-Jun
If memory serves, on that headunit there is a kill switch that when turned off or disconnected causes the face to stay shut.
My buddy has one I will ask him about it.
thanks....i'll try to get the exact model & tell me your' friends so that i can figure this thing out.......its a great unit.....when its working
Alright. He said the unit doesn't even power on without that switch lead grounded or power (can't remember which right now) . The manual I got for his from kenwoods site had the diagram to show how to hook it up.
make sure the tracks on the side are not bent *at all*. That's the biggest thing that gets screwed when you take them out.. slight bend and it jams the face
On the harness for that unit should be a wire that says security or some such ****. It's basically a power wire that is run to a switch. If the switch is off the unit doesn't get power. If you find that wire and it is in truth a power wire (consult your manual rather than my memory) you can just hook it to your switched 12V lead and the unit should power up.
What is your model number?
Skeeter7424
Audio / Security / Video
20
May 27, 2006 09:45 PM
