FOR SALE: APEX-i Power FC standalone....w/ FC commander
Old Oct 16, 2003 | 09:09 AM
turbochic's Avatar
Default FOR SALE: APEX-i Power FC standalone....w/ FC commander
FOR SALE Apex-i Power FC,
<U>NEW PRICE....$850.02 +shipping OBO</U>
It is used only one month.
below is just a bunch of info..taken off of the apexi site.
please email me with offers and questions....thank you
email at fmaxturbochic@hotmail.com
The Power FC proudly stands as A'PEX's answer to the constraints and limitations associated with most piggy-back style fuel controllers. The Power FC is a complete, stand alone, total engine management system capable of handling virtually anything thrown in its path. From multiple point fuel and ignition control to VTEC engagement (Honda applications) and boost settings, the Power FC is capable of accommodating even the most demanding performance enthusiasts.
Currently available only through Power Excel Shops, the Power FC replaces the factory ECU and controls all engine parameters.(Off road use only, no OBD-II) Installation is as easy as replacing the factory ECU. (Some minor rewiring is required on select vehicles.) The factory engine harness does not need to be replaced and all critical accessories such as air conditioning continue to function. By using the optional FC COMMANDER, the user can adjust and modify a wide range of settings. By changing various parameters and data, the Power FC will adapt to any of your performance needs. Since there is no need to upgrade ROM chips or trade in ECU's, the factory ECU can be kept by the original user.
The Power FC operates off of three Main Menus. These menus are : Monitor, Setting, and ETC.
In Monitor Mode, the Commander can display up to 10 parameters of data in real time. Monitor Mode can display:
Engine RPM
Ignition Timing
Vehicle Speed
Air Flow Voltage (Pressure Sensor Voltage)
Injector Duty Cycle
Boost
Knocking Level
Battery Voltage
Intake Air Temp
Water Temp
In addition, there are 4 display patterns allowing 1-8 parameters to be shown on screen at once. The data displays in numerical real time values with the option of a real time 10 second graph display. Peak Hold values and Display Hold functions only require the touch of a button. The Map Trace Mode allows Ghost Map Tracing of the Fuel Correction and Ignition Timing maps. This allows the user to visually see what point of the map is being used in real time. The Ghost Map Trace function leaves markers on the used portions of the map for easy reference.
Setting Mode allows full access to the 20x20 ignition timing and fuel correction maps. The user can adjust any portion of this map in 5x5 sections. Air flow correction values can be entered for vehicles upgrading air flow meters. Injector pulse correction menu is used when upgrading injectors on the engine. The Acceleration Enrichment Correction function improves response under hard and sudden acceleration. The Cranking Fuel Injection menu corrects the amount of fuel when the engine is being cranked, or when the water temperature is cold. A separate Water Temp menu allows fuel correction according to water temperature. The RPM menu allows rev limiter settings and idle RPM levels. Access menus also vary according to specialty engines. Rotary engine Power FC's accommodate leading and trailing ignition maps. Honda engines Power FC's allow for VTEC control. Complete boost control is possible by using the optional Boost Control Kit (Not necessary for vehicles that come factory turbocharged.). Changing data is easy: just access the desired point on the map or data, and push the FC COMMANDER keys in the appropriate direction.
The ETC Menu contains utility parameters such as : version information, LCD screen Brightness, and Initialization of all Data. In addition, the ETC Mode allows the user to monitor all factory sensors through one screen. This screen can tell the user if any sensor is in use or malfunctioning.
The Power FC also comes preprogrammed with several base maps. (Currently with Japan Domestic Market Vehicle Maps. Minor initial tuning may be required. Please contact your authorized Power Excel shop for more information.) This makes the initial tuning process much quicker. As with all other fuel controllers, the POWER FC should be tuned on a dynomometer by a trained professional. A high grade air/ fuel ratio monitor is also recommended during tuning to ensure best results.
FC COMMANDER
The FC COMMANDER is a hand held controller designed to allow access to the vital parameters within the Power FC. The unit allows a wide range of data modification through its large back lit LCD display. The unit has been designed so that one finger can control a wide array of data. Once connected, the Apex logo will appear in the screen taking the user to the Main Menu. From here, the user can access the three Main Menus (Monitor, Setting, Etc.) The FC COMMANDER "communicates" with the Power FC control unit thereby creating one of the first interactive user friendly fuel management systems.
Modified by turbochic at 3:16 PM 10/21/2003
Modified by turbochic at 10:49 PM 11/10/2003
Modified by turbochic at 2:56 PM 11/25/2003
Old Oct 16, 2003 | 07:19 PM
turbochic's Avatar
Default Re: FOR SALE: APEX-i Power FC standalone....w/ FC commander (turbochic)
ttt
Old Oct 17, 2003 | 02:08 PM
havok hybrid's Avatar
Geez. someone is going to be happy.. This systems Rocks... and thats a Great Price.....
Bump to the bang bang .. the boo-iedy beat
Old Oct 17, 2003 | 06:07 PM
Default Re: FOR SALE: APEX-i Power FC standalone....w/ FC commander (havok hybrid)
Bump!.......... ............
Old Oct 19, 2003 | 09:51 AM
what the BUMP !!!
Old Oct 21, 2003 | 08:56 AM
EG6owner-T's Avatar
bump for a better price, by the way is it new?
what make and model is it made for?
Thanks.
Old Oct 21, 2003 | 02:05 PM
turbochic's Avatar
Default Re: FOR SALE: APEX-i Power FC standalone....w/ FC commander (EG6owner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6owner &raquo;</TD></TR><TR><TD CLASS="quote">bump for a better price, by the way is it new?
Thanks.</TD></TR></TABLE>
it is not new...only used for one month tho
PERFECT PERFECT CONDITION
Part # Vehicle
Honda/Acura
414-H003 96-98 Civic EX (U.S.)
414-H003 96-98 Integra GSR/LS/Type R (U.S.)
Old Oct 24, 2003 | 08:11 AM
turbochic's Avatar
ttt tt t t t tt tt t tt tt t tt tt tt tt t t t t t t t t t
Old Oct 27, 2003 | 08:43 AM
turbochic's Avatar
bump again
Old Oct 27, 2003 | 09:31 AM
1.8EG-T's Avatar
Just curious, is this one fo the self tuning kits, that gets you in the neighborhood before major tuning at a dyno, kinda like the tec 2 system?
Old Oct 28, 2003 | 11:29 AM
turbochic's Avatar
Default Re: FOR SALE: APEX-i Power FC standalone....w/ FC commander (hybridrex)
im not sure
i am not familar with those products...this is however and awesome product for an awesome price..
i have to sell this to pay off some of my debts!!!
please buy this!!!!
Old Oct 28, 2003 | 12:19 PM
RenoRacing's Avatar
bump for a homie's homie!
Old Oct 30, 2003 | 11:39 AM
Default Re: FOR SALE: APEX-i Power FC standalone....w/ FC commander (RenoRacing)
Come on .. christmas is coming.. someone grap this thing.
Old Oct 31, 2003 | 12:40 AM
Arturbo's Avatar
Better than steak
25 Year Member
Up for a great deal!!
art
Old Oct 31, 2003 | 06:24 AM
legendboy's Avatar
Default Re: FOR SALE: APEX-i Power FC standalone....w/ FC commander (Arturbo)
is this one of the new units that come equiped already equiped for boost? does it come with the solinoid valve for the boost controller? If it does i'll probably pick it up off ya!
Old Nov 1, 2003 | 09:21 PM
turbochic's Avatar
Default Re: FOR SALE: APEX-i Power FC standalone....w/ FC commander (legendboy)
bump again...i need to sell this ppl
make offers
will consider...but no lowballers!!!!
Old Nov 10, 2003 | 12:02 AM
turbochic's Avatar
BUMP&gt;&gt;&gt;&gt;&gt;&gt;&gt;&gt;&gt;&lt;&lt;&l t;&lt;&lt;&lt;&lt;&lt;&lt;&lt;BUMP
Old Nov 10, 2003 | 09:48 PM
turbochic's Avatar
OKAY OKAY...new price so bump for new price
Old Nov 11, 2003 | 02:59 PM
Selling for for 950 shipped..????????WOW Wish i was OBD 1
Someone should pick it up...
Old Nov 11, 2003 | 08:32 PM
porsche997dc2's Avatar
for girl racer.
Old Nov 12, 2003 | 10:29 AM
turbochic's Avatar
and theeeennn
Old Nov 13, 2003 | 09:51 AM
turbochic's Avatar
bump
Old Nov 13, 2003 | 02:22 PM
Jkan2001's Avatar
bump for a really good price and a cool girl
Old Nov 17, 2003 | 07:50 PM
2K_TEG's Avatar
Default Re: (Jkan2001)
ttt
Old Nov 18, 2003 | 06:16 AM
2K_TEG's Avatar
bump
