240+whp possible with my current setup
PR3 head mods are as follows- P&P by portflow. welded combustion chamber 3 angle valve job. skunk2 stage 2 cams and cam gears portflow valvetrain.JG intake manifold portmatched and bored out to 70mm for str 70mm throttle body.rc injectors 440 and AN-R header.
B18A1 bottom end-bored and honed to 86mm sleeved by GE.knife eged crank and polished.IB wiseco pistons with raised wrist pins 14:1 compression.eagle rods, balanced and blueprinted bottom end.JERRYBUILT
p28 HONDATA s200
J1 tranny. Is 240+whp possible with my new set up thanks.
p28 HONDATA s200
That has the potential for 240+ for sure... Weve done it several times before with similar set ups so I see no reason as to why you couldnt hit 240 with yours
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost »</TD></TR><TR><TD CLASS="quote">I'd say yea, but use Skunk Stage3's instead of 2's you got the compression so you might as well use them. Perhaps 250whp with those!</TD></TR></TABLE>
See sig
And yes 240 is possible
See sig
