[FAQ] Differences in CRX's.
I'm lookin to buy a CRX. I've been looking at a couple of 91's, and i don't really know much at all about CRX's. I've only heard of Si's and LX's. Is there any major differences in the models, like the motor and stuff like that. Is there a certain model thats better to get than others?
D16A6 Honda Civic Si/ CRX Si 1988-1991 108HP/100 TQ
-MPFI(4 injectors)
-mated with 5spd tranny(4.25 final drive)
-best candidate for a swap or A6 buildup due to little modification of wiring harness and the hubs will accept most axles
-90-91 CRX Si's had 4 wheel disc brakes all other models (exc EX coupes) had rear discs
-common swaps: ZC DOHC, D16Z6/Y8(sohc vtec), B16A, B18C, B18C5, B20Z/B, H22A
D15B6 Honda Civic HF / CRX HF 1988-1991 62HP/83 TQ
-MPFI(4 injectors)
-crappy 5 speed tranny geared for gas mileage
-good candidate for a swap because: lightest chassis, little modification to wiring harness, although hubs will need to be swapped for SI/DX hubs to accept any other axles if using a non HF tranny
-common swaps: ZC DOHC, D16A6, D16Z6/Y8(sohc vtec), B16A, B18C, B18C5, B20Z/B, H22A
D15B2 Honda Civic DX/LX, CRX DX 1988-1991 92HP/89 TQ
-DPFI(2 injectors)
-5 speed tranny geared for MPG, better than HF tranny, STD models have 4 speed tranny
-for swap you must first convert to MPFI via an HF/SI wiring harness and resistor box. Most abundant model in my opinion and cheapest but most work although you can also add your own wiring to become MPFI.
-MPFI(4 injectors)
-MPFI(4 injectors)
-DPFI(2 injectors)
88-89 CRX's don't have side impact beams in the doors, the 90-91 do.
All CRX's have rear drum brakes except the 90-91 Si's
90-91 have a round instrument gauge cover while the 88-89 one is more squarish
88-89 door moldings are taller and flatter, the 90-91 ones are shorter but stick out further and have a beveled edge to them.
90-91 rear lights have a 1/2 inch black edge all the way around them, the 88-89 do not.
90-91 have have fake air ducts molded into the bumper
88-89 have slightly different front and rear bumpers than the 90-91
90-91 bumper mounted turn signals are clear with amber inserts in them, the 88-89 lenses are just solid amber and shorter in length.
88-89 Corner mounted parking lights have their mounting screws visible while the 90-91 ones are attached by hiden screws.
91 and perhaps 90 headlights have a vent in them to help prevent moisture buildup.
90-91's are the heaviest, the 89 is lighter, and the 88 is the lightest. In each year the hf is the lighter model, then the DX and finally the Si weighs in at the most.
88 manual transmissions have an input shaft with 21 slpines
88 has a 21 spline input shaft, the 89-91's have a 20 spline shaft
90-91 clutch is 212mm, the 89 is 200mm and the 88 has either a 200 or 190mm, I can't remember which.
88 does not have a clutch safety switch. Which means it will start without having to press the clutch in.
88-89 Si models have 105hp, the 90-91's have 108hp due to different ecu settings and possibly a slightly different cam.
88's have pillar mounted seatbelts,90-91 have door mounted belts, 89 si's and dx's have door mounted belts, 89 hf's have pillar mounted belts. I could be wrong on some of this belt stuff, if you can confirm or deny any of it please let me know.
Models with door mounted belts have a wider pillar at the end of the door to accomodate the belt mount, this also means that the glass is and inch or so shorter.
90-91's have a red seatbelt warning light built into the dome light.
Rear lower control arms changed between the 88 and 91 years and the rear shocks have different mounting points but I'm not sure what year the change took place.
88 has slightly different sized front shocks.
88 ecu has a different internal design than the 89-91 but the inputs and outputs are the same and ecu's can be swapped between years. I know this one since most chip makers don't offer a chip for the 88 and my car was a gunea pig for Dinan to test a later year ECU on.
88-89's have the hazard light switch on the top of the steering column, 90-91's have it mounted on the dash.
88-89 Si seats have a white pinstrip, 90-91 Si seats have a red pinstrip.
88 has a pocket at the bottom of the drivers door
90-91 Si's and perhaps the 89 Si have a mesh pocket on the back of the seats.
88 cam indexing is the same for all the engines, 89-91 si's have indexing that is different from the other engines.
90-91 and possibly the 89 have larger reverse lights that are set further to the sides than the 88
Weight Differences By CRXBart:
1988 CRX HF 1819lbs.
1988 CRX DX 1922lbs.
1988 CRX Si 2011lbs.
1989 CRX HF 1834lbs.
1989 CRX DX 2048lbs.
1989 CRX Si 2138lbs.
1990 CRX HF 1967lbs.
1990 CRX DX 2103lbs.
1990 CRX Si 2174lbs.
1991 CRX HF 1967lbs.
1991 CRX DX 2103lbs.
1991 CRX Si 2174lbs
CRX Forum
Modified by crxforum at 2:22 PM 6/1/2006
1991 CRX Si 2174lbs
CRX Forum
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yebabee »</TD></TR><TR><TD CLASS="quote">
-90-91 CRX Si's had 4 wheel disc brakes all other models (exc EX coupes) had rear disks
I'll go ahead and be the token nitpicky bitch. all other models had drums . easy enough brain fart to make. just wanna clear it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxhf89 »</TD></TR><TR><TD CLASS="quote">i thaugh only the 91 si had rear disc but i could be wrong</TD></TR></TABLE>
90-91 crx si's..
90-91 crx si's..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker »</TD></TR><TR><TD CLASS="quote">
90-91 crx si's..</TD></TR></TABLE>
Correct
Correct
yebabee(or ne one that would knw),,,,,,, u say that the hubs need to be changed to si hubs in a hf??? i have a hf wit b18, i did not do the swap, and i was lookin for rotors for it and ive been told that the hf rotors are differnt than the other crx's, so does that mean that i can order si rotors and they should work??? or am i just confused????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ridexstraight »</TD></TR><TR><TD CLASS="quote">yebabee(or ne one that would knw),,,,,,, u say that the hubs need to be changed to si hubs in a hf??? i have a hf wit b18, i did not do the swap, and i was lookin for rotors for it and ive been told that the hf rotors are differnt than the other crx's, so does that mean that i can order si rotors and they should work??? or am i just confused????</TD></TR></TABLE>
Yeah, they'll bolt up fine..I have an 88 STD with SI rotors/calipers..Fits perfect
The only set-up that wont work is from the 90-91 ex civic..
psh my old 89 HF had 61 horses...someone stole my 62nd horse. by the way i got that thing goign 110 and it started smoking.. dont know why im talking about my old winterbeater ill leave...BUMP !!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haggar »</TD></TR><TR><TD CLASS="quote">And STD Civics don't have a 92 HP D15.. only 70 hp....</TD></TR></TABLE>
std engine is the same as the dx, 16v d15b1/2 only with a 4speed
HF had the 8 valve d15 with sixty-some horsepower.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic »</TD></TR><TR><TD CLASS="quote">Let's test this knowledge here!
Will 88 si doors fit well on a 90-91 body? </TD></TR></TABLE>
On the CRX they will, doesn't even look goofy if you get the right interior panels. Don't know for sure on the Civic.
I'm guessing that you may want to modify the CRX once acquired.
if so, avoid the DX...
it's a little easier with the Hf but ideal to modify the Si.
Unless you want the lightest chasis, then go with the HF.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham »</TD></TR><TR><TD CLASS="quote">
No its not ..STD engine has 70hp..DX engine has 90hp..
The power difference has something to do with the restrictor plate..
yet a few more differances not yet mentioned:
90-91 si's had suede flip down mirrors (on the side that hitts the roof wile the 88-89's had vinyl
also late 89's and 90-91's had the eprom ecu (alot easier for chipping)
90-91's have a "bladed looking wheel wile 88-89's have a older looking rim both 14's
im on my 2nd crx
also have 88 dx hatch
and 89 civic si
great post
im on my 2nd crx
and 89 civic si
great post
