gsr with ctr pistons? will it work?
Old Oct 16, 2003 | 01:01 AM
fastciviccoupe's Avatar
Default gsr with ctr pistons? will it work?
I currently building a ls/v and im using ctr pistons on ls rods with arp rod bolts. My question is will this work? is there going 2 be a clearence issue? i will be using stock cams then upgrade 2 itr cams then plan on using some aftermarket stage 2's like crower or skunk2. So will it work? please help me out.
P.S.- I did a search so please dont post if you going 2 tell me 2 search i need help asap..
thanks
Old Oct 16, 2003 | 04:37 AM
advanracing62's Avatar
Default Re: gsr with ctr pistons? will it work? (fastciviccoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastciviccoupe &raquo;</TD></TR><TR><TD CLASS="quote">I did a search so please dont post if you going 2 tell me 2 search i need help asap..</TD></TR></TABLE> sure you did...
The answer is Clay your motor. That's the only REAL way to tell. With stock cams I would say yes you're fine, ITR cams.. yes.... II cams... CLAY!!!!
Old Oct 16, 2003 | 07:37 AM
EF_LSVtec's Avatar
Default Re: gsr with ctr pistons? will it work? (advanracing62)
We have an lsvtec in the shop (CTR pistons, Toda Spec C cams), no clearance issues...but of course, nothing better than clay to find out how much exactly you can play with.
Old Oct 16, 2003 | 09:37 AM
black sohc civic's Avatar
Default Re: gsr with ctr pistons? will it work? (EF_LSVtec)
seen many setups with this, yes it will work but clay anyway. spell check and do a search for ctr pistons achieved.
Old Oct 17, 2003 | 10:58 AM
all right thanks for the replys
Old Oct 17, 2003 | 01:15 PM
GOLDBERG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote"> sure you did...
The answer is Clay your motor. That's the only REAL way to tell. With stock cams I would say yes you're fine, ITR cams.. yes.... II cams... CLAY!!!! </TD></TR></TABLE>
if you clay your motor and have clearance issues...what then?
Old Oct 17, 2003 | 01:31 PM
badCRX's Avatar
New User
Default Re: gsr with ctr pistons? will it work? (GOLDBERG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GOLDBERG &raquo;</TD></TR><TR><TD CLASS="quote">
if you clay your motor and have clearance issues...what then?</TD></TR></TABLE>
Thicker headgasket from Cometic.
Ra GS-R
Aug 10, 2007 03:09 PM
AllMotor12s
15
Apr 13, 2004 06:21 PM
Dominicandude
10
Jan 21, 2004 07:09 PM
JUNcr-x
Nov 21, 2003 06:19 AM
Justin95GSR
Apr 14, 2003 04:54 AM
