b16 with ctr piston
all help wanted and all times wanted.
i know this is not the fastest or the best thing out there but i want to know what ctr piston can do. i have a stock b16 in a 95 hb and thinking about putting ctr piston in there. what can i expect from this?? high 13 maybe?? i know people have done this b4 so how much will this cost me to get it done or should i just buy a different block. just want to bump up cr. one thing at a time, next will be head but not till later. thanks in advance
One CTR piston won't do **** for you but 4 CTR pistons would be nice
Also you can't determine what the car will run by the mods on it there are WAAAAAAAAAAAAAAAAAAAAAAAAAAAY to many factors.
I believe it will bump your compression up to 11:1 correct me if I'm wrong anyone.
i'd spend a couple extra bucks and get a gsr block....you'll notice a lot more power from that than you would any piston upgrade in a b16...unless you bore of course
I have too considered the gsr block but for 1250 you cant beat a b16, plus some motor work will definately outpower a gsr for a lot less money. THis is of course for the obd-0 b16.
theslugbug
11
Jul 11, 2004 12:39 PM
