Best cams/vavletrain setup for the buck?
Lookin to install a vew valvetrain and cams to accompany my new Skunk2 Cam gears and Skunk2 IM...
I was thinkin ITR valvetrain/CTR cams?
Any other ideas? Also what headgasket for better CP
PM Tweakmeister, trust me, I talked with him online and he won't give you any hassle, just tell you the facts and prices
here is the site though http://www.hogens.com/
keep in mind that Not JUST ANY valvetrain is compatible with ANY camshaft. There are valvetrains out there that are way too STIFF for some cams out there. You have to pick a valvetrain that has the right spring pressure, specs for the cam you are using.
Just by saying... this "brand" is the best pick, doesnt mean its has the right spec for everysetup.
In general, I'd just use the OEM ITR ones to upgrade the stock valvetrain if you arent really planning on using a big cam. but if you do plan on using a big cam like JUN3 or SKUNK2 stg 2, then CHOOSE the proper valvetrain for that setup.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94BlackCivicEX »</TD></TR><TR><TD CLASS="quote">Lookin to install a vew valvetrain and cams to accompany my new Skunk2 Cam gears and Skunk2 IM...
Any other ideas? Also what headgasket for better CP</TD></TR></TABLE>
I would go with what you have there.
ITR valvetrain with CTR cams!
Im just looking for a nice daily driver, nothin super friggin fast...ok i lied. But i want somethin reliable
So far CTR cams/ITR valvetrain are winning lol.
Will they help me go to 200 whp (including headwork etc)?
Goal: 200 whp without juice, then 250~whp with juice
You'll want stiffer springs than ITR if you run OE retainers. Consider yourself warned if you don't heed this advice. Valve Float is a real problem on these motors especially if you mis-shift.
We run 280+lbs on the nose of our cams for 1+ years at 11k rpms with no problems. There is heresay and their is experience. I've have stated what I know from experience.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rhetoric »</TD></TR><TR><TD CLASS="quote">skunk stage 1's, itr valvetrain friendly...</TD></TR></TABLE>
GSR valvetrain friendly too. I've been running my stage 1's on my stock valvetrain for awhile now. No problems whatsoever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">GSR valvetrain friendly too. I've been running my stage 1's on my stock valvetrain for awhile now. No problems whatsoever.</TD></TR></TABLE>
Are you making good power at 8200 RPM? I was just hoping to make use of the higher rev for more power...
I saw your dyno run and it was bad ***, and Ive got a similar setup to urs (quite close) so im kinda excited
Teamdiesel
16
Sep 3, 2017 08:34 PM
hamizle
Jan 16, 2009 11:52 AM
