check engine light but no codes? here are my problems...
Old Oct 15, 2003 | 05:23 PM
dingusjt's Avatar
Default check engine light but no codes? here are my problems...
Ok i have a check engine light that turns on about 5 minutes after starting my car and stays on for the duration.
i've already checked for codes and nothing is coming up, before i was getting the VSS error but since i re-installed my stock cluster and evertyhing, i haven't had any problems but now i'm not getting any codes at all just that damn continous check engine light..
the only problem i have with my car is a erratic idle bouncing from 1K-1.2K, i've changed my eacv and checked all my vaccum lines...
also often when i release the gas or am accelerating my car will jerk for about a second...
these so far all the only symptoms i have, does anyone have any idea whats going on? oh yeah and my car is completely stock now d15b2
Old Oct 15, 2003 | 07:10 PM
Grease Monkey's Avatar
Default Re: check engine light but no codes? here are my problems... (dingusjt)
did you try reseting the ecu?
Old Oct 15, 2003 | 07:18 PM
speed_racer012's Avatar
Default Re: check engine light but no codes? here are my problems... (Grease Monkey)
is it the right ECU
Old Oct 15, 2003 | 07:42 PM
dingusjt's Avatar
Default Re: check engine light but no codes? here are my problems... (speed_racer012)
reset the ecu already....and yeah i think its the right ecu...pm5 for dx
Old Oct 15, 2003 | 09:43 PM
moysaystor's Avatar
I hate that dam continous CEL. I'm expriencing the same dilema on MY vehicle.
everything works but the vtec and that dreading light stays. I gonna try to sort through my wires on the OBD 0-1 conversion i did. I'm praying ill my problems lies there.
As for the problem with the CEL, the manaul says to test a well known ECU. If the new ecu works then theres your problem. However the manaul doesn't say what to do if the problem presists on the, "known good ECu". "
Old Oct 16, 2003 | 08:22 AM
dingusjt's Avatar
any more suggestions??
Old Oct 16, 2003 | 08:49 AM
temp's Avatar
there are no codes blinking at all? could be a bad ECU? try changing ECUs w/ a friend or something to see if that fixes it....also for your idle, check your air boost valve (if equipped)
Old Oct 16, 2003 | 09:18 AM
spaceman's Avatar
everything is hooked up correctly right?all your ground connections..check your timing,maybe your fuel filter is getting clogged,throttle body/intake manifold gaskets,get your injectors cleaned..check your throttle cable and rotor for sticking or smooth operation..and the list goes on
90dteg
Sep 18, 2008 12:54 PM
89civichb
May 10, 2007 06:42 PM
jdm82
Mar 7, 2006 01:08 PM
BseriesHatch
Sep 15, 2004 08:46 PM
