tranny block brace question
Old Oct 15, 2003 | 02:26 PM
brownman72000's Avatar
Default tranny block brace question
I am about to get a header and was wondering if the bottom tranny block brace has to come off.....
1. will it afftect anything in a negative (ie. the way it mounts, the way it perfroms)
2. how hard is it to complete this task
3. how do you go about doing it
Thanks!!!
Old Oct 15, 2003 | 05:54 PM
BlueR's Avatar
Default Re: tranny block brace question (brownman72000)
Every off-the shelf header designed for the ITR application is designed with the tranny block brace in mind...custom headers are a different story and you will have to ask the person making it
Old Oct 15, 2003 | 05:57 PM
t's Avatar
t
1. It was designed to stiffen up the tranny to motor, plus its used as a flywheel cover
2. couple of bolts
3. Remove the header; unbolt the brace.
Old Oct 15, 2003 | 06:04 PM
Pondus's Avatar
Default Re: (t)
I just bolted on my Hytech header today and had to grind off a bit of the tranny to give room for the header. I believe the same goes for the SMSP header. It took me 1/2 hour to unbolt the brace, grind off some metal and bolt it back up.
phileng04
Dec 5, 2009 05:43 AM
TPB
May 17, 2006 11:25 AM
jeremy.
May 18, 2005 05:48 PM
slowerthanu
Mar 24, 2002 10:14 AM
