What fuel reading do i use?
Old Oct 15, 2003 | 08:45 AM
DropSquadCivic's Avatar
Default What fuel reading do i use?
i'm trying to see how much fuel presure i'm running but i don't know what reading to go off of. It show's 2 different reading off of my fuel gauge:
1. when the car is at idle it reads 30 psi.
2. when i engage the throttle it shooots up to 40 psi.
how much psi should i be running on my h22 swap, i was told 40psi what do you guys think?
Old Oct 15, 2003 | 08:56 AM
mmuller's Avatar
Mad Scientist
Default Re: What fuel reading do i use? (DropSquadCivic)
40 psi should be fine, you should check with vaccum line to fpr disconnected, that will show you fuel pressure the car will see wot.
Old Oct 15, 2003 | 10:29 AM
JimBlake's Avatar
Default Re: What fuel reading do i use? (mmuller)
The FPR is always trying to keep your fuel pressure 40psi above whatever pressure's in your manifold. So when you're idling your manifold has 20" of vacuum, which is about -10psi.
Old Oct 18, 2003 | 11:51 PM
Default Re: What fuel reading do i use? (JimBlake)
so you guys are saying that my current fuel pressure is 30psi, i should be reading it when it is in idle.
Old Oct 19, 2003 | 10:07 AM
chrisCNL's Avatar
boost your pressure to 43 psi. you can still do it when the car on idle. just take of the vaccum hose that connects to the FPR and it will read the reading like it is at full throttle.
Old Oct 19, 2003 | 03:21 PM
JimBlake's Avatar
Default Re: What fuel reading do i use? (chrisCNL)
Yeah, disconnect the vacuum line from the FPR, plug it so it's not a vacuum leak, & leave the nipple of the FPR open. Now measure your fuel pressure. That's a more reliable measure since your manifold vacuum might be fluctuating.
afnan
Jan 12, 2014 05:16 AM
Tchleung
Oct 18, 2004 01:48 PM
tegtip
May 19, 2003 07:39 AM
TakaIntegra
Jun 17, 2002 09:55 PM
BeeT
Jun 18, 2001 10:00 AM
