Unable to locate ECU plug 92 ex
Old Oct 15, 2003 | 08:24 AM
Bluezman's Avatar
Default Unable to locate ECU plug 92 ex
I am unable to locate the ECU test connector in my 92 Accord EX. The service manual says it's located under the dash on the passenger side, and shows a 2 wire connector hanging down from the dash near the passenger door. There is no 2 wire connector there that is not already in use.
I have removed the plastic panel in the corner, near the door and pulled back the carpet to expose the the ECU and cover plate. Still no luck.
There is, a six wire connector under the plastic panel mounted to the body. this comes from under the dash, but has a jumper that shorts all six wires to ground.
Can anyone tell me where it could be hidden, or what color it is?
Any information would help. Thanks
Old Oct 15, 2003 | 08:47 AM
v4lu3s's Avatar
RTFM
its blue and typically taped up inside the dash sort of behidn the plastic panel in the corner.
Old Oct 15, 2003 | 08:57 AM
Bluezman's Avatar
Default Re: Unable to locate ECU plug 92 ex (Bluezman)
Found it. It was where they said it was. Duh. It was taped to some other wires and looked like it was just a lump in a harness.
BTW The connector is blue, the wires are orange/red, and green/white.
Old Oct 15, 2003 | 09:04 AM
Bluezman's Avatar
Default Re: (v4lu3s)
Thanks v4lu3s, right on the money. It was that tape thing that got me.
Maybe I expected to put my hand out and have the connector fall into it
Old Oct 16, 2003 | 08:07 AM
v4lu3s's Avatar
RTFM
lol well at this point most ofo teh ones in my cars DO fall out if you look sideways at them since i never taped em back up
JayNeil
Feb 12, 2011 02:54 PM
friesx100
Feb 15, 2008 12:41 PM
19992civichatch
Jun 24, 2007 06:39 AM
allricedout
Dec 28, 2006 07:38 PM
Frankei
Nov 4, 2005 06:47 PM
