Who/where can i get good after zc engine parts?
I hope someone can help!
Can anyone tell me where i can get good aftermarket engine components (cams, pistons, rods, cranks, valvetrain etc etc) for my crx zc engine.
Any websites or shops would be great thanks!!
Dan!!
Dan!!
for pistons and rod's you'll use standard d series components. For valve springs, etc you'd need to spend a grip & get B18A/B items installed. Exospeed can hook you up w/ reground cams, most other items will be d series stuff.
http://www.dh-racing.com They do the headwork to use an LS valvetrain in a ZC. It will cost you, but I think it's worth it if you have high goals for your ZC.
Thanks peeps,
Is the zc pistons the same as your sohc d-series pistons?
So i should be able to get rods, pistons, rings etc from places like raceeng.com?
That power service imazu i have heard off, hmmmmmm....see if i can get my japanese contact to find info out on their products?!
Thanks for the link to dh racing
Does the ls/b18a fit straight into a zc engine?
I would like to build up the zc motor i have in my jdm si, and then turbocharge it.
I've seen some of your sohc d series engines running 350-400hp, and i would like to get near that sort of figures!
Thanks for the help lads!!
Dan!!
p.s. sorry for all my basic questions, trying to research as much as poss before i go ahead with this
Dan!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">since you are in england PSI parts would be easier for you to get and would produce more power....word</TD></TR></TABLE>
yea, i know what you mean, its easy with my japanese friend, he can import me anything really.
I'll have a scout round and see what i can find out.
Dan!!
Dan!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project91CRX »</TD></TR><TR><TD CLASS="quote">Which means you can hook a ZC brother up that lives in the states.
haha.....will dude ....let me see what i can find out mate
can u hook up a uk dude aswell?
Dan!!
</TD></TR></TABLE>haha.....will dude ....let me see what i can find out mate
Dan!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by temp »</TD></TR><TR><TD CLASS="quote">ok the company PSI that i was talking about actually stands for
"power service imazu".....try looking that up</TD></TR></TABLE>
how'd you find out about them? cataglogue or some sort?
NOOOOOOOOOOOOOOOOOO! Dont do that stupid ******* LS valve train conversion! Its a waist of ******* money mang! Go to http://www.theoldone.com Larry Widmer has valves, pistons of all compression ratio's and rods. You can aquire valve springs and retainers for the zc from any EF-1 dealer.
The ls conversion seriously ***** the motor since the LS head has completly different geomitry.
If you plan on revving to the moon use the EF-1 springs and some shims.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan Norton »</TD></TR><TR><TD CLASS="quote">
Dan!!</TD></TR></TABLE>
can you get me a 1.6i-VT cluster for cheap?!?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDABOND »</TD></TR><TR><TD CLASS="quote">NOOOOOOOOOOOOOOOOOO! Dont do that stupid ******* LS valve train conversion! Its a waist of ******* money mang! Go to http://www.theoldone.com Larry Widmer has valves, pistons of all compression ratio's and rods. You can aquire valve springs and retainers for the zc from any EF-1 dealer.
i still like my idea, we must remember is in england, getting parts from america might be more costly then getting them from japan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jockette »</TD></TR><TR><TD CLASS="quote">
how'd you find out about them? cataglogue or some sort?</TD></TR></TABLE>
well i was reading the hyper rev magazine and i remember that PSI has a TON of ZC parts
high compression pistons
cams
cam gears
valve train components
individual throttle bodies
and more
i think they even have a stroker kit for it, and if he could find it mugen used to make an intake manifold for it, they also used to make a turbo kit for the ZC......
cams
cam gears
and more
