Which Piston Rings for CTR Pistons
I am building an LS/VTEC with CTR Piston (Standard Bore). Which Piston rings are to be used with them???
As far as OEM Honda rings, do I have to buy CTR Piston rings??? (If so, does anyone have a picture with the part number???)
OR can I go to my local Honda dealership and by Civic Si B16 Piston wrings??? (I think they are P30 Pitons.)
From: South LA...107th and fig to be exact...for the foo
the factory rings are real good just use those... ctr piston rings and b16a rings share the same part number
Are you sure??? not doubting you, i just don't wanna have to explain to the folks at Honda that I bought the wrong ones, and i don't know what pistons i have, lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1797ccs »</TD></TR><TR><TD CLASS="quote">the factory rings are real good just use those... ctr piston rings and b16a rings share the same part number </TD></TR></TABLE>
, dunt have the part no handy tho
Okay, I just ordered my Piston Wrings today from Honda for my CTR Pistons.
The Part number on the receipt 13011-PR3-003 is for a '00 Civic Si.
Is that Correct???
Is that Correct???
If the car is strictly a street car, I will use onda rings when possible. If I am building a higher performance engine, I will use low tension rings to cut back on internal friction.
I NEEDED THAT INFO ALSO I WAS WONDERING IF U HAVE 2 MACHINE NE THING OFF THE CTR PISTON IF U PUT IT ON AN LS ROD I HAVE 95JDM B16A2 HEAD 99 BLOCK WILL THE PISTONS FIT WITH NO PROBLEMS OR MODS TO THE PISTONS WITH OUT ANY VALVE CLEARANCE ISSUES
You will need to machine 1mm of each side of the rod to squeeze CTR pistons on to an ls rod.
As far as clearance, with pistons like those of CTR's nature you should clay your motor to check for valve clearance.
-sander
-sander
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99 ls integra »</TD></TR><TR><TD CLASS="quote">does maching off a 1mm effect the strength of the rod or r they milling of the length of the rod </TD></TR></TABLE>
Nothing to worry about.
You can have your machinist machine the piston to fit the rod instead of the other way around. THat is how my CTR pistons were done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sander »</TD></TR><TR><TD CLASS="quote">You will need to machine 1mm of each side of the rod to squeeze CTR pistons on to an ls rod.
-sander</TD></TR></TABLE>
Chief Wenceslaw
Mar 18, 2006 11:20 AM
vtec69
Nov 21, 2001 06:47 AM
