bearings and oil pressure
Old Oct 14, 2003 | 09:07 PM
toooslow's Avatar
Default bearings and oil pressure
do bearings play a major role with oil pressure? like if a bearing or bearings went bad is it possible for oil pressure to drop dramatically?
Old Oct 14, 2003 | 09:10 PM
spaceman's Avatar
Default Re: bearings and oil pressure (whiteinteg95)
i would think so..i know what happens if they run dry and its not good
Old Oct 14, 2003 | 09:35 PM
mmuller's Avatar
Mad Scientist
Default Re: bearings and oil pressure (spaceman)
your oil pressure would drop, but i dont think a lot unless you spin a bearing, but then you have bigger problems.
Old Oct 15, 2003 | 08:29 AM
toooslow's Avatar
could you explain to me how faulty bearings or a spun rod bearing makes oil pressure drop, i just dont understand.
Old Oct 15, 2003 | 08:39 AM
CHEETAH's Avatar
Default Re: (whiteinteg95)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whiteinteg95 &raquo;</TD></TR><TR><TD CLASS="quote">could you explain to me how faulty bearings or a spun rod bearing makes oil pressure drop, i just dont understand. </TD></TR></TABLE>
the clearance between the bearings and the crank's journal helps to pressurize the oil, if you look at any journal there are oil galleys that transfers oil between the bearings and the crank journal. The oil between there causes pressure, so too much clearance will result in deficit in oil pressure as the oil will come out easily wihtout any resistance.
Another misconception that people don;t understand is the width of rod bearings with respect to crnak journals, i.e. compare a b20 or LS rod bearing to that of a GSR or ITR, the latter is much skinnier than the LS/B20 - I've seen people use GSR bearings in an LS rod/crank and have detrimentally low oil pressure, then they spin the bearings and blame it on revving to high when in fact it was because the bearing did not cover the entire journal so oil was *escaping*
Greg
Old Oct 15, 2003 | 10:47 AM
toooslow's Avatar
Default Re: (CHEETAH)
you explained that damn well, thank you
Aquafina
28
Jan 16, 2008 10:55 AM
precisionelite
Aug 22, 2005 10:37 AM
DjDrift
Oct 14, 2004 07:35 PM
dustin
Oct 23, 2002 12:06 PM
