changing antifreeze
Hi, I need to know how to get most of the antifreeze out of the engine. If i use the drain it will only get some out,does the prestone kit you can buy where you cut a hose and add an adapter work well?
Thanks fellas
Thanks fellas
you need to drain the rad.
drain the coolant from the block.
and you need to take out the air bleed bolt to let all the air out of the system.
do pressure and voltage check after.
try to catch all the anti-freeze, dont kill mother earth yo
gailT25
Feb 23, 2009 04:39 AM
