Question about tire and rims??
Old Oct 14, 2003 | 08:49 PM
TaZ326's Avatar
Default Question about tire and rims??
Hi,
i am kind new here, now i am planing to change my rims and tires,
the tire's size is 185/70/14,
if i want to change the rim to 15" or 16", what's the size of tire i suppose to use?
if there is any chance, is someone's used rims r for sale?
Please let me know, because i don't have too much money....
one more question, how can i change my fuel filter?
do i need a special tool?
thx
Old Oct 14, 2003 | 09:17 PM
94AccordCoupe's Avatar
Default Re: Question about tire and rims?? (TaZ326)
15's - 195/60/15
16's - 205/50/16
17's - 205/45/17
Fuel filter is a pain in the ***, wouldn't mess with it unless your having a problem. There suposed to last the life of the car.
Old Oct 15, 2003 | 05:06 AM
JimBlake's Avatar
Default Re: Question about tire and rims?? (94AccordCoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94AccordCoupe &raquo;</TD></TR><TR><TD CLASS="quote">Fuel filter is a pain in the ***, wouldn't mess with it unless your having a problem. There suposed to last the life of the car.
</TD></TR></TABLE>Not for ALL cars... The pump inlet screen is supposed to last the life of the car, but some Hondas ALSO have a filter in the engine compartment.
On my '95 Integra, you just need normal wrenches to change it.
Old Oct 15, 2003 | 05:21 AM
KGAccord's Avatar
Default Re: Question about tire and rims?? (JimBlake)
^civic and teg fuel filters are easy, accords and ludes are a different story. i changed mine when they did swap, but i would reccomend it at timing belt changes regardless of what the dealer says since it says to in the shop manual.
Old Oct 15, 2003 | 07:24 PM
im_the_teacher's Avatar
Default Re: Question about tire and rims?? (KGAccord)
it is hard when you don't have the right tools and the right resourse..
Old Oct 15, 2003 | 07:35 PM
TaZ326's Avatar
thx for all of u!!
Old Oct 15, 2003 | 08:08 PM
iam7head's Avatar
NO, they will not.
believe me there's maintenace you need to do, fuel filter is one of those.
they are 25 buck from honda, 10 buck from autozone.
it's not hard to change, it just take time.
little knowledge of the pressurized fuel system would help.
anyway ever change a fuel filter in a dsm, yeah, it's HARD
little preview if you want to do it.
you'll need some basic tool(10 and 12 mm socket, wrench, rag,etc)
fuel filter of course(it should come with all washer, they are very important, no dont use the old one)
-take out the battery(fuel+spark=boom)
-make a mark with a perminent marker or something so you would over tighten the filter, there's no torque spec on the filter neither.
-release the pressure in the system(there's a release valve)
-wrench out the inlet and outlet bolt(banjo) with a 10-12mm socket wrench
-take out the old filter(it's a firebomb, dont even think of washing it) and the old washer, clean the fitting.
-reverse the step, tighten it to the marking.
-turn the key to "on"(dont start yet), let the fuel pump pump enough gas to the entire system, go out and change for leaks.
-start the car, check for leak, if there's none, apply throttle and go back and check for leak. if everything goes well, take a slow test drive.
CRuNCHyEM1
Dec 19, 2010 11:37 AM
actek23
Jan 8, 2008 05:48 PM
swatteamtimmah
Jan 22, 2006 06:19 AM
ToxicBug
Apr 27, 2005 06:55 AM
