Does your car shift rough when cold?
Old Oct 14, 2003 | 08:34 PM
Steve90HB's Avatar
Default Does your car shift rough when cold?
Anyone else have this problem? My car shifts really rough when it's cold, gotta ride the clutch in each gear until it finally reaches about halfway on the thermostat
is this just maybe my tranny or is it all hondas? it is a 91 si hatch
Old Oct 14, 2003 | 08:39 PM
JonGP4's Avatar
Default Re: Does your car shift rough when cold? (Steve90HB)
yeah mine does the same thing, i figure its cuz the clutch is just gripping really good since its not warm yet.
Old Oct 14, 2003 | 08:45 PM
solman74's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve90HB &raquo;</TD></TR><TR><TD CLASS="quote">Anyone else have this problem?</TD></TR></TABLE>
I have an 89 hatch with a B series swap. I've never had this issue. I replaced the clutch. I put AFT fluid with Dextron in it. It shifts like butter no matter what. I have a tad bit grinding in 3rd but I'm gonna rebuild it and replace the gearing so I can get a tad bit better topend. I'm gonna go with a nice set of synchro's as well. If it's hard to get into and out of gear. Trying switching to the AFT fluid or the GM synchro mesh or if you have a plan jane trani try mobil 1 motor oil full Synthic. I used that in 1.6 sohc D series motor and It work like a champ. Hope this helps.
Old Oct 14, 2003 | 09:42 PM
insomniac791's Avatar
no do not use mobile one full synthetic in your tranny. It is bad for the syncros. If you are going to use oil use regular 10-30 non synthetic or some Honda MTF I have also heard good things about redline too. I am planning on changeing my tranny fluid this week I have a Y1 w/LSD and I am going to use GM Syncromesh modified in it.
later
Matt
Old Oct 15, 2003 | 04:45 AM
bloopie's Avatar
Default Re: (insomniac791)
Yes, and I have had 3 EF's and an EG and it did it on all of them.
Car just needs to warm up!
818wHtEG6
10
Feb 12, 2007 06:10 AM
allmotorbl
10
Jun 12, 2006 03:18 PM
95greenteg
May 11, 2006 04:50 PM
baonest
Dec 19, 2005 02:16 PM
ofl
Feb 2, 2004 08:24 AM
