cam gear over-advanced by accident
Old Aug 31, 2001 | 12:29 PM
GruvyTune's Avatar
New User
Default cam gear over-advanced by accident
While changing cm gear settings, the intake cam gear was accidentally set to 8 degree advance. Things ran kinda rough and the car was driven on the highway for a test run before figuring out this was the problem. Obviously it was set back again and things appear to be running ok. I assume the worst thing that can happen is piston/valve contact. Is there any simple way to check if any damage was done? Compression had been like new before. Would this be sensitive enough of a test?
thanks!
Torin
Old Aug 31, 2001 | 12:49 PM
92CivicSiR's Avatar
New User
Default Re: cam gear over-advanced by accident (GruvyTune)
If there was piston to valve contact it more than likely would have broken the valve resulting in a blown motor. If everything appears to be normal, then I would not worry about it. If you want to re-check everything, then go ahead and do a compression test. If there is a broken valve or something in there, you would most definately notice it in a compression test.
JFG Kevin
Jul 19, 2006 07:49 PM
DEMNTD1
10
Nov 2, 2005 09:09 PM
SioneSi
Jun 18, 2003 11:36 AM
powerfulperformance
Aug 15, 2002 02:47 PM
