**NEED HELP**, 1st gen CRX [86] with a b18 no-tec swap
Old Oct 14, 2003 | 05:57 PM
90njteg's Avatar
Banned
Default **NEED HELP**, 1st gen CRX [86] with a b18 no-tec swap
bout to start my b18 swap and wanted to hear from anyone whos already done it for tips or problem areas. will be swapping a b18a1 into a 86 crx hf. will be using a holley commander 950 ecu so the wiring will not be an issue,but i would like the speedo to work and dont know how to hook it up with the new engine. anyhelp would be great. thanks
Old Oct 16, 2003 | 05:08 AM
90njteg's Avatar
Banned
Default Re: **NEED HELP**, 1st gen CRX [86] with a b18 no-tec swap (90njteg)
bump for help
Old Oct 16, 2003 | 06:21 AM
whizzlefist's Avatar
you need to replace fuel tank and lines to run injection.. and the hf speedo can be connected with the vss. there is a guy called b16destroyer over at
http://www.redpepperracing.com
which you should b e reading anyways, he did a b18 swap
Greeneski
Classic Hondas
Jul 10, 2017 06:59 PM
Mfsmoov
Aug 14, 2015 05:22 AM
clampjaw25
May 19, 2007 11:42 AM
JDMHondaPro
Jan 19, 2004 03:28 PM
-sir-
Apr 26, 2003 08:42 AM
