Turbo for a GSR on a LS?
Old Oct 14, 2003 | 03:45 PM
RedTegLS's Avatar
Default Turbo for a GSR on a LS?
I see a lot more kits for GSR's than I do for LS's. Will a GSR turbo kit fit on my LS? If modification is needed what exactly? Thanks!
Old Oct 14, 2003 | 03:56 PM
MiraiZ's Avatar
Default Re: Turbo for a GSR on a LS? (RedTegLS)
Depends on the kit....It'll fit...the downpipe may be too big though...may need to get another one made to be be able to mate up with the stock cat....also the turbine may also be big, causing some turbo lag...otherwise everything else should work
Old Oct 14, 2003 | 03:58 PM
quikB18B's Avatar
Default Re: Turbo for a GSR on a LS? (MiraiZ)
Only problem i see is the charge pipe, it will need a little modification because of the different IM.
AzNsTyLe361
Jun 24, 2007 04:26 PM
BoOstInHaRd
Jan 16, 2005 12:41 PM
.doeboyfresh.
Sep 15, 2004 02:37 AM
ahobbs
Feb 24, 2003 03:36 PM
subhuman456
Feb 14, 2003 10:10 PM
