WBo2 Narrow band o2 sim-------where should I tap on the harness?
I need to intall my wideband and I need to run some wires to the stock o2 sensor wireing - whats the best way to do this.
My first thought is run a cable through that hole with the rubber on it where the ecu harness is and run it to the sensore wire - maybe I should look in the helms to see if I can trac it closer.
Suggestions?
Suggestions?
killerb7888
10
Oct 29, 2013 07:47 AM
