GSR and ITR b-pipe the same?
Would I be able to bolt up a 00-01 GSR b-pipe to a 00-01 ITR muffler? I heard that after 1999, all Integras have the same cat-back. Except that the ITR muffler flows better. Does anybody have more info on this?
ITR B pipe is mandrel bent.
GSR B pipe is crush bent.
ITR/GSR B pipe lengths are different due to resonator size.
ITR/LS B pipe lengths are the same.
ITR B pipe has a second tiny resonator near the end that goes to the muff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Primo. »</TD></TR><TR><TD CLASS="quote">ITR B pipe is mandrel bent.
ITR B pipe has a second tiny resonator near the end that goes to the muff.</TD></TR></TABLE>
1st part is right, 2nd reason is kinda on track except that the main difference is that 94-99 GSR B pipes are longer by about 5" than all other 94-01 Integra B Pipes including the 00-01 GSR. So All the rest are the same length but the 94-99.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-Rizzle »</TD></TR><TR><TD CLASS="quote">Would I be able to bolt up a 00-01 GSR b-pipe to a 00-01 ITR muffler? </TD></TR></TABLE>
Yes you can.
Yes you can.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Mike M »</TD></TR><TR><TD CLASS="quote">
Yes you can.</TD></TR></TABLE>
do u know if there is a difference in b-pipe length between the 00-01 DC2 and DB8 or are they the same too? how about axleback portion? is the only difference in the exhaust tip length?
