Cooling Fan wont turn on...
Old Oct 14, 2003 | 12:38 PM
90Accord-R's Avatar
Default Cooling Fan wont turn on...
My fan motor (passenger side... not sure if this is the AC condenser fan or main cooling fan?) burned out the bearings, so I replaced the motor, and now the fan wont turn on! Car heats up when sitting in traffic now, and the fuse seems fine. Any ideas?
Thanks.
Old Oct 14, 2003 | 03:30 PM
accord's Avatar
the collent temp sensor in the water neck jump it together and see if the fan turns on if it doesnt something else it wrong but does sensors tend to go out
Old Oct 14, 2003 | 05:21 PM
KatyHonda's Avatar
Default Re: (accord)
The condensor fan (pax side) should turn on when AC is commanded regardless of coolant temp. If fan doesn't engage when AC is commanded, then you have defective fuse or condensor fan relay.
good luck
Old Oct 15, 2003 | 12:38 PM
90Accord-R's Avatar
Default Re: (KatyHonda)
Thanks for the advice, I'll try those suggestions...
Also, it seems as if the cooling fan (driver side) also will not turn on, unless the condenser fan is running? Could this be a bad wire somewhere? Are the fans looped together in the wiring? Either way, the cooling fan should turn on if the motor is warming up, right? The fuse looks fine, but the fuse connectors look like there is a bit of oxidation on them... I'll try cleaning those to get a better connection...
Old Oct 15, 2003 | 05:35 PM
silvercrxsi88's Avatar
Default Re: (90Accord-R)
Check thermostat, fan sensor, temp sensor, and fan relay
Old Oct 15, 2003 | 05:50 PM
KatyHonda's Avatar
If the AC is turned on with condensor fan coming on, and radiator fan(driver's side) didn't come on, you most likely have either 1) bad radiator fan, bad radiator fan wiring, bad radiator fan fuse, or bad radiator fan relay. It is possible, but less likely that the radiator timer unit is faulty and not providing power to radiator fan relay.
good luck
Old Oct 17, 2003 | 07:30 AM
90Accord-R's Avatar
Thanks everyone... going to try all this stuff this weekend... I'll put up a reply to let y'all know how it works out...
Thanks again...
-Ryan-
therest
Dec 5, 2016 04:40 AM
hatchyksp
Sep 4, 2010 05:25 AM
josemt
Jun 23, 2010 06:24 AM
Paluce
Mar 20, 2007 09:33 AM
