Is there such thing as an obd-1 zc?
Old Oct 14, 2003 | 10:58 AM
lelopez's Avatar
Default Is there such thing as an obd-1 zc?
Just like the title says, couldn't find anything with "search" and want to know if this guy is full of it (although I see obd1 plugs in there)
http://cgi.ebay.com/ebaymotors...33615
thanks in advance,
L.
Old Oct 14, 2003 | 11:14 AM
Mikey's Avatar
Default Re: Is there such thing as an obd-1 zc? (lelopez)
I would say yes as the 20th ann. Civic in Japan came with the ZC.
Old Oct 14, 2003 | 11:17 AM
lelopez's Avatar
Default Re: Is there such thing as an obd-1 zc? (Mikey)
Anywhere I can find info on these? According to the post it is supposed to be rated at 140 hp.
thanks,
L.
Old Oct 14, 2003 | 03:44 PM
1990civicsiguye's Avatar
yea there is a obd1 zc its the 92 model like the man said the 20th anniversay....
Old Oct 14, 2003 | 03:55 PM
lelopez's Avatar
Now that it has been established, does it really have 140hp? Nippon motors says it is rated at 130hp.
L.
Old Oct 14, 2003 | 05:51 PM
mntuner2's Avatar
I kind of say yes. You may run into problems with the firewall/intake manifold clearence. Keep in mind that pic is a 92-95 civic (USDM years) It will bolt up but the wiring is up to you.
Old Oct 14, 2003 | 06:12 PM
lelopez's Avatar
Default Re: Is there such thing as an obd-1 zc? (mntuner2)
Well, I'm comfortable with obd1 conversions....I've done quite a few.
Old Oct 14, 2003 | 06:14 PM
mntuner2's Avatar
Then I'd say, do it! You've got nothing to loose but your knuckles
one more thing, bolt up manifold first to check the clearence. Looks good, kick ***!
Old Oct 14, 2003 | 06:54 PM
conceptEG's Avatar
there are the following zc's
obd-0 sohc & dohc
obd-1 dohc and sohc.. both cable and hydro trans available..
i use to work at noyanusa.. a jspec engine importer in manassas va
when i got my swap.. i saw the clean dohc valve cover.. walked up to it.. saw grey injectors.. ok obd-1 b16a.. wait.. no v-tec .. then i saw a cable trans?? looked at the engine stamp.. just "zc"
Old Oct 14, 2003 | 08:04 PM
Garrett's Avatar
The OBD-1 DOHC ZC is rated to 137 hp
digitalcongo
Jan 22, 2014 05:11 PM
D7_62
Classic Hondas
Aug 6, 2012 07:36 AM
tyler100
Jan 15, 2009 07:02 AM
baboracus
Aug 11, 2006 12:39 PM
Jmorin
Oct 16, 2003 07:06 AM
