what are u measuring when doing a compression test?
Old Oct 14, 2003 | 10:57 AM
silverEH2's Avatar
Default what are u measuring when doing a compression test?
when u are doing a compression test, you are measuring the maximum pressure a cylinder will hold.....correct
Old Oct 14, 2003 | 11:33 AM
Perfectionist's Avatar
Default Re: what are u measuring when doing a compression test? (silverEH2)
Actually you are measuring the amount of pressure a cylinder will produce after several strokes. The compression tester will hold the presure inside itself. That's why there's a presure release button on it.
To test if the cylinder itself holds presure you would have to stop the stroke at top dead center exactly and watch a gauge that doesn't store the presure. It isn't very usefull or practical to do this. However, there is a 'leak-down' test that is similar in principle. This test determines where the cylinder is losing presure (valves, rings, etc) and how badly.
Old Oct 14, 2003 | 11:48 AM
silverEH2's Avatar
Default Re: what are u measuring when doing a compression test? (Perfectionist)
well after every bump your numbers would keep getting higher and higher until they cant get any higher which would give u the compression for that cylinder?
Old Oct 14, 2003 | 11:54 AM
1bad-eg's Avatar
Yes, you are correct.
Brandon Peters
Oct 18, 2015 05:37 PM
06BlackSi #45
Honda Civic (2006 - 2015)
Nov 22, 2009 06:55 AM
91EF919
18
Aug 4, 2009 12:50 PM
92vxjdm
Aug 15, 2008 05:05 AM
dreamreaperx
Dec 20, 2006 02:01 PM
