What trannies bolt on to a D series block
Old Oct 14, 2003 | 10:18 AM
Mr. 1582's Avatar
Default What trannies bolt on to a D series block
What trannies bolt on to a D series block ?
Old Oct 14, 2003 | 10:41 AM
RickChew's Avatar
Default Re: What trannies bolt on to a D series block (Mr. 1582)
Trannys from other D-series. As long as they are hydro (or cable, whatever matches your set up) Rick
Old Oct 14, 2003 | 10:58 AM
Mr. 1582's Avatar
Default Re: What trannies bolt on to a D series block (RickChew)
What tranny would be the best to use
Old Oct 14, 2003 | 11:03 AM
2faz2paz's Avatar
what car do you have what is your setup?
Old Oct 14, 2003 | 11:06 AM
USDMMARK's Avatar
depends on what year set up you have, for d series you could get a hydro tranny from 92+ and 91 and under you could get a cable, for cable i have the d16a6 tranny of the si civic/crx if you got hydro go with a d16z6 tranny off of a ex (92-95) or a d16y8 tranny from a 96+ ex
ALL OF THE ABOVE WILL FIT, ANYTHING D WILL
i probley screwed something up but figure out what tranny you got and go from there the three trannys i listed are short geared trannys
Old Oct 14, 2003 | 11:12 AM
EGinNY's Avatar
Default Re: What trannies bolt on to a D series block (Dr.D)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr.D &raquo;</TD></TR><TR><TD CLASS="quote">depends on what year set up you have, for d series you could get a hydro tranny from 92+ and 91 and under you could get a cable, for cable i have the d16a6 tranny of the si civic/crx if you got hydro go with a d16z6 tranny off of a ex (92-95) or a d16y8 tranny from a 96+ ex
i probley screwed something up but figure out what tranny you got and go from there the three trannys i listed are short geared trannys</TD></TR></TABLE>
Also want to know bout this, i got an ex tranny(or so i was told when i got the car) but i heard there is a difference between ex coupe n sedan..the gears are the same but final drive on a ex sedan was same as dx final drive....either way i hate the tranny 3rd is too long/slow, somethings not right..what other trannies are there...del sol sohc lsd?? know anything bout it or others
Old Oct 14, 2003 | 01:37 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: What trannies bolt on to a D series block (EGinNY)
EX coupe and sedan have the same gearing. It is possible that some of the sedans got the del slo .750 5th instead of .702 5th gear.
Travis922
Jul 30, 2005 10:03 PM
Si Shane
May 15, 2005 11:54 AM
Suck my DX
Apr 6, 2005 12:09 PM
