Upgrading 89 Si transmission
Old Oct 14, 2003 | 07:15 AM
teamrushhatch's Avatar
Default Upgrading 89 Si transmission
I've seen this around a few forums that i have been in can someone tell me how this works... cause its been said that i can upgrade it to use the 92-95 clutch, and flywheel.
Old Oct 14, 2003 | 07:34 AM
virginia_dude's Avatar
Default Re: Upgrading 89 Si transmission (teamrushhatch)
'91 Civic uses the 212 MM clutch
Old Oct 14, 2003 | 09:34 AM
Malgerus's Avatar
Default Re: Upgrading 89 Si transmission (virginia_dude)
90-00
212 mm clutch.
Old Oct 14, 2003 | 09:37 AM
Default Re: Upgrading 89 Si transmission (Mr. S)
Ok I stand corrected, 90 and up have larger clutch, will help a little. pre '89 had smaller clutch with '88 being a weirdo with odd spline count compared to all other years.
Old Oct 15, 2003 | 10:52 AM
so is it possible or is it not possible to use the 92-95 clutch
Old Oct 15, 2003 | 11:04 AM
Don't have an answer, try to see if part numbers of 90-91 are the same, if they are you are set, however first hand experience I can not offer. Maybe someone who has actually compared the tow or have done it has an answer.
Old Oct 15, 2003 | 11:20 AM
xci_ed6's Avatar
http://www.cardomain.com/id/krustindumm90
check out the drivetrain section.
-Dustin
Old Oct 15, 2003 | 11:23 AM
xci_ed6's Avatar
Default Re: Upgrading 89 Si transmission (krustindumm)
Actually, here:
SOHC Clutch Info
It is all the stuff I have been learning while/to modify my car. Still have more stuff to dump out of my brain .
-Dustin
elmalouno
Nov 8, 2008 04:45 AM
K2e2vin
Mar 29, 2006 10:58 AM
mugensport9
10
Sep 23, 2003 09:01 PM
civteg1
Sep 29, 2002 10:24 AM
