Amp to Power Alpine Type R Sub
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg88 »</TD></TR><TR><TD CLASS="quote">I want to spend as little as possible without sacraficing safety or too much performance.</TD></TR></TABLE>
still doesn't help too much. give us an actual number.
Is it a DVC and what ohm's is it? If its a 2 ohm DVC then you'll need a amp that'll put out about 400watts rms at either 1 or 4 ohms. If its a 4 ohm DVC, you'll need a amp thats rated at 2 or 8 ohms. 2 and 1 ohm amps draw more current from your battery so most likely they'll be Class D amps and require heavy gauge cabling. The Alpine MRD-500 is great at 2 ohms.
I will second the suggestion that you get the 801D for the Type R, that combo sounds damn nice together, although with your price range of 100-130 for an amp that needs to put out at least 300WRMS will be hard to come by...
EVIL_AWD
Audio / Security / Video
13
Jul 18, 2003 12:14 PM
b18tdelsol
Jan 7, 2003 08:25 PM
