what times should my hatch run
i have a 92 si eg with a 97 ls motor so far the motor is stock im running a t60-1 stage 5 ballbearing turbo with fmic the fuel system is h22 injectors with a walbro in tank pump with 2 extra 440cc injectors on the charge pipe. im running a 35 shot of nos to help spool the turbo which has a .82 ar on the exhaust side and a full dc cat back exhaust . the car will run on 24 inch slicks with traction bars at about 12 psi of boost. the ignition is set up with a msd digital sci plus and msd wires and coil with a msd btm... what times should i expect out of this set up at e town...thanks
t60-1si
Oct 13, 2003 10:25 PM
datspeed77
Jun 20, 2002 08:49 AM
